Trani broke. pics :)
Old Feb 9, 2003 | 08:16 PM
shortyz's Avatar
Default Trani broke. pics :)
hah from a few weeks ago.. how does this happen i cant figure it out..
Old Feb 9, 2003 | 08:50 PM
Broken Gearbox's Avatar
Default Re: Trani broke. pics :) (shortyz)
Maybe you cant drive ...anyways i dont know how that happen but that sucks
Old Feb 9, 2003 | 09:05 PM
-16V-'s Avatar
Default Re: Trani broke. pics :) (x lP lL i c i t)
Damn that looks bad how did that happen?
were you driving when that happen?
Old Feb 9, 2003 | 09:51 PM
Toptul_Honda's Avatar
New User
Default Re: Trani broke. pics :) (1991_jdm_sleeper)
haha yeah maybe you cant drive
Old Feb 9, 2003 | 10:12 PM
drjondurst's Avatar
someone explain for the dummies out there what happened.
Old Feb 9, 2003 | 11:39 PM
shortyz's Avatar
Default Re: Trani broke. pics :) (drjondurst)
i cant drive ? **** u cracka.
was driving up my driveway. went clunk and she didnt move anymore..
Old Feb 9, 2003 | 11:45 PM
91_hatch_si's Avatar
what am i looking at?
Old Feb 9, 2003 | 11:53 PM
Louie B.'s Avatar
Driving with a worn out differential bearing, bearing finally went, throwing parts into the diff, parts got caught in the spider gears, jamming them up. and turned your diff into a spool (you probably had great "posi" traction for a short while) until you turned a corner and the wheels wanted to spin at different speeds, causing the diff to self-destruct.
Now, what caused the differential bearing to wear out? possibly bad installation of an Axle. Or perhaps slammed suspension shoving axle into bearing. or maybee tranny out of fluid. we may never know for sure.
A proper autopsy of the tranny may reveal more.
How did I do? did I pass the test?
Old Feb 10, 2003 | 12:42 PM
shortyz's Avatar
Default Re: Trani broke. pics :) (thumpu77)
no the bearings were fine..
im stumped.
Old Feb 10, 2003 | 07:29 PM
Louie B.'s Avatar
what's that ring in pic#2? I thought that was the outer ring of a bearing, and that's how I came to my conclusion. none of the bearings were missing any *****? It still looks to me like some sort of debris got into the spider gears and jammed them up.
Old Feb 10, 2003 | 08:31 PM
civicdragger818's Avatar
Hey Ive had two S1 tranny's do this and both of them happened on an incline such as your talking about. I think that might have something to do with it.
Old Feb 11, 2003 | 12:37 PM
therealciviczc's Avatar
Default Re: Trani broke. pics :) (civicdragger818)
We had one do this too. No sign of bearing problems. My friend pulled out of a McDonalds, and just a tiny clink sound, and the car rolled to a stop. The diff had come out through same spot in the trans. We never figure out what did it.
I know that provides no insight, but at least you're not alone in not knowing.
*** His was a stock 1991 Integra. ***
[Modified by therealciviczc, 9:37 PM 2/11/2003]
Old Feb 11, 2003 | 02:17 PM
*Boostwerks*'s Avatar
Heres what happened.....
The middle shaft that the diff gears rotate on WERE NEVER hardened by Honda. They only started hardening the shaft in 92. Once the shaft wears out enough the gears can slid on the shaft essentially exploding the DIff.
Just ask Mista Bone about this one. He know's all about it...
Old Feb 11, 2003 | 07:19 PM
Louie B.'s Avatar
Default Re: Trani broke. pics :) (Bryson)
Well, that's nice to know that the tranny I just got done re-building with all new syncros, seals, and bearings could still explode at any time for no aparent reason because it still has the original diff!!
Old Feb 11, 2003 | 07:23 PM
Blaze45's Avatar
Brrraaaap!
_______
that sucks
Blaze
Old Feb 11, 2003 | 07:37 PM
MADEINIRAQ's Avatar
Default Re: Trani broke. pics :) (Blaze45)
i think that happened to my old trans after i sold it to my friend...... still haven't taken it apart but you can see the gear layin.
Old Feb 11, 2003 | 07:44 PM
Default Re: Trani broke. pics :) (madeiniraq)
Unfortunatly many 88-91 S1 owners have this problem.
Old Feb 11, 2003 | 08:10 PM
ameenit's Avatar
Ouch! Good luck on the new tranny man..
Old Feb 11, 2003 | 08:18 PM
MADEINIRAQ's Avatar
Default Re: Trani broke. pics :) (crxaccord)
i went ahead and replaced mine with a J1
Old Feb 11, 2003 | 08:32 PM
You can see the wear in the shaft.
Old Feb 12, 2003 | 02:39 PM
HandCommand's Avatar
Yes, Yes, Yes, I recognize that pic of a worn shaft. This happened to my B20a5 old school Prelude a couple of years ago during an autocross event. I have a pic like that one of the worn shaft on the ends.
I think its something that wears over time and finally lets go. Auto crossing my Prelude while my CRX was in the making just accelerated the weak worn shaft in my LUDE tranny.
Its wierd to see someone else post up a pic of that shaft. You are not alone, my friend.
Now Im curious to as where those pics of mine went. i think they were normal photo pics I took, not digital.
Old Feb 12, 2003 | 03:27 PM
driftt's Avatar
wow that sucks, but its good news for me, i need a clutch release arm, and the upper stay thing the clutch cable runs though for my s1 tranny, mine are both bent from the previous owner of my car using the wrong clutch cable and bending the **** out of them to make it work, can anyone wth a blown one help me out? im in md btw....
Old Feb 12, 2003 | 03:31 PM
driftt's Avatar
Default Re: Trani broke. pics :) (driftt)
here is a bad picture of what i need, god im a *****....
Old Feb 12, 2003 | 08:00 PM
wignersfriend's Avatar
New User
Default sure?
it may be too out of focus, but it looks just like mine. In fact, I thought my clutch arm was bent too, but in the 93 Integra Helms diagrams they draw it bent, so I figured it was ok. Maybe yours is worse than the picture appears...
Old Feb 13, 2003 | 05:01 AM
driftt's Avatar
Default Re: sure? (wignersfriend)
yea im positive its bent the **** up, its a bad pic i know, so anyone got one to sell me???
