again...skunk2 adjustable upper control arms.
Old Feb 9, 2003 | 07:53 PM
Phoenix_ITR's Avatar
Default again...skunk2 adjustable upper control arms.
i've already done a search and read pretty much every thread involving the Skunk2 pieces -- i came across pretty mixed reviews, to say the least.
i've already ordered the arms to be used in conjunction with my current spoon spring/stock shock setup. i came across a number of instances in which the arms slipped -- this does not seem to be that big of a deal to me, and i'm sure that i can correct it with minimal effort. however, i also came across problems involving both the balljoints as well as problems with the A-arm contacting the fenderwell. can anyone shed some light on either of these problem
also, will i have to modify the arm in any way in order to make it work well, and if so, how would i go about doing this? thanks for all your input.
-tony
Old Feb 9, 2003 | 10:50 PM
tC_Dragon's Avatar
Default Re: again...skunk2 adjustable upper control arms. (delinquent)
i've had mine in for about 3-4 weeks now and have not had any knockin on my upper fender well, so interpret that as you like. As for squeeking, i had a little the first 2 days, then it all just went away. So i actually think i over tightened where the arms bolt up and that the rubber busshings were squeeking against the a arm but now its all gone. But honestly, i just couple days ago heard about the problem that migs had with his balljoint and am a bit concerned with it. I am pretty close to skunk2's/group A's location so was considering headin over there to talk to them about it when i get the time. I hope that gives you some more input. Oh and as far as the slipping, well, i haven't had it on my car yet, and to my recollection it happened on some of the other members cars becuase they didn't tighten down teh allen head bolts enough. But i could be wrong
Old Feb 9, 2003 | 11:25 PM
Default Re: again...skunk2 adjustable upper control arms. (pdcdragon)
hmm...thanks for the info.
please let me know if you do talk to the skunk2 distributor -- i'd appreciate that.
-tony
OmgDelSol
Suspension & Brakes
Aug 28, 2014 03:13 PM
1993_EJ1
Jan 5, 2011 11:51 PM
kungfuSiR
Jul 30, 2003 11:41 AM
Phoenix_ITR
14
Feb 10, 2003 01:55 PM
Phoenix_ITR
Feb 10, 2003 06:42 AM
