Calculating compression on this setup?
Old Feb 9, 2003 | 07:40 PM
VtecDA9's Avatar
Default Calculating compression on this setup?
LS block decked .008
USDM ITR pistons
b16 head milled .030
stock head gasket
I tried at c-speedracing, but wasn't sure how to calculate the decking and milling
Old Feb 9, 2003 | 07:49 PM
altoid's Avatar
Default Re: Calculating compression on this setup? (VtecDA9)
subtract the .008 from the piston deck clearance and .03 from the gasket thickness
Old Feb 10, 2003 | 11:33 AM
TimoneX's Avatar
New User
Default Re: Calculating compression on this setup? (EE4)
Somwhere near 11.95:1. Check your valve to piston clearance...shouldn't be a problem though, depends on cams.
monster_c
Apr 5, 2012 09:53 AM
vajdmeg
Jan 30, 2009 11:01 AM
WorrGame13
Mar 30, 2007 03:35 PM
fr3dy_1
Nov 23, 2006 09:22 AM
boostd ls
Jan 16, 2006 10:57 PM
