Any tricks for compressing the rear brake piston?
Old Feb 9, 2003 | 03:02 PM
flybert's Avatar
Default Any tricks for compressing the rear brake piston?
Do you guys have any tricks on compressing the piston in the rear brake caliper for a 96 accord?
Old Feb 9, 2003 | 03:11 PM
f0rum's Avatar
Default Re: Any tricks for compressing the rear brake piston? (flybert)
My guess would be the same as an integra/civic you rotate it clockwise
Old Feb 9, 2003 | 03:12 PM
ejprimo's Avatar
Default Re: Any tricks for compressing the rear brake piston? (f0rum)
you can buy the special tool at kragen.
Old Feb 9, 2003 | 03:26 PM
Dr. EKology's Avatar
What usually works for me is putting a small piece of wood against the piston, then use a C-clap to compress the piston.
Old Feb 9, 2003 | 03:33 PM
eg6sir-s's Avatar
you dont compress the rear disc brake caliper piston...you stick a wide enough flathead screw driver on the piston and turn it counter-clockwise.
Old Feb 9, 2003 | 03:44 PM
Default Re: Any tricks for compressing the rear brake piston? (eg6si)
I should have stated that my procedure was what i do for front discs, since i don't have discs in the rear i thought they would be the same .
Old Feb 9, 2003 | 03:49 PM
migs's Avatar
Counter Clockwise? I could have sworn last time I did my friends GSR brakes, I turned it clockwise?
Old Feb 9, 2003 | 04:21 PM
flybert's Avatar
Thanks. Just rotated it and it worked. One more question. How does that thing work if it's threaded like that. How does it back out while your braking?
Old Feb 9, 2003 | 04:25 PM
shawnhayes's Avatar
Default Re: Any tricks for compressing the rear brake piston? (EKology)
Nope. You will DESTROY the caliper if you do that.
My favorite way to make a reply like yours is "I've never done that myself, but, wouldn't you do it the same way as a front and use a C-clamp?".
If he'd listened, he'd be screwed, wouldn't he?
Shawn
Ezduzit2500
Jun 11, 2018 05:21 PM
bibong
Mar 22, 2009 09:15 AM
Inextricabledrvr
Dec 28, 2008 05:42 PM
WVhump
Acura TL, RL & ZDX
Apr 4, 2007 05:22 PM
medside
Apr 26, 2005 11:12 AM
