Type R Sway Bar Rubbing Brake Lines
Old Feb 9, 2003 | 01:30 PM
bluecivic107's Avatar
Default Type R Sway Bar Rubbing Brake Lines
I have a 2000 Integra GSR with a 2.5" drop. Recently installed a Type R Sway Bar with a kit similar to BSQ, but made by yours truly. Noted that Sway Bar is Rubbing on the Brake Line Metal Bracket.
Anyone experiencing this. I checked my installation, everything looks good with the above exception. Any suggestions??? Thanks in advance for any responses!!!
Old Feb 9, 2003 | 04:24 PM
Tweakmeister's Avatar
Default Re: Type R Sway Bar Rubbing Brake Lines (bluecivic107)
I cut the brackets.
some just take them off.
Old Feb 9, 2003 | 08:13 PM
ALF's Avatar
ALF
Can you post a pic by any chance? I have a '94 and did not experience this problem. I'm curious as to where exactly it is rubbing.
Old Feb 10, 2003 | 06:27 AM
BSQ's Avatar
BSQ
Default Re: Type R Sway Bar Rubbing Brake Lines (ALF)
I think what might be happening is that the Type-R rear swaybar is making contact with a ABS sensor wire bracket on the lower control arm (LCA). I had a similiar issue, but it really wasn't making a noise. I just noticed on the swaybar that it had a small contact mark on it.
If you look at this picture ( http://www.imagestation.com/picture/...2/fdd0cbfd.jpg ) you will see the ABS sensor bracket attached on the LCA.
Here is what I did to resolve the issue. I first loosened the bolt which hold the ABS sensor wire bracket to LCA. I then placed a screw driver between the bracket and the LCA and bent the bracket back slightly. This allows the bracket to fit in the indentation of the LCA. I also took a metal file and filed the edge off of the bracket. This prevented the swaybar from making contact bracket.
HTH
Old Feb 10, 2003 | 04:56 PM
Default Re: Type R Sway Bar Rubbing Brake Lines (BSQ)
BSQ...You are absolutely RIGHT ON!!! There is a clunking noise that is evident went suspension travels too much. I know for a fact that it is the brackets holding the Brake Sensor.
Thank you for your suggestion as well as others!!!
Deluzional
Mar 24, 2004 07:51 PM
bluecivic107
Feb 9, 2003 05:21 PM
BeanRacer
Jan 10, 2002 03:23 PM
Scooby
Oct 10, 2001 08:16 PM
