Caster setup for z10
Old Feb 9, 2003 | 11:24 AM
12seccrx's Avatar
Default Caster setup for z10
I have an 88 rex w/b20, I recently installed the z10 member. I can't seem to hook very well, and the car is a handful to drive. Best 60" w/22x8x13 is a 1.88, with alot of wheel spin. 215hp 146tq, 12.6 @ 111.5 spinning. What specs should it be set at for drag racing? Thanks
Old Feb 9, 2003 | 11:41 AM
littlebluecrx's Avatar
Default Re: Caster setup for z10 (12seccrx)
I would get the car on a alignment rack, the car should not be handfull, unless the caster is not even side to side. A little bit of positive caster , pre load can help, but the main thing is to make sure the caster is even side to side, and make sure your 4 wheel alignment is straight.I would also check that the upper control arm is not warn out, years ago my car got real unstable all of a sudden turn's out the upper ball joint on drivers side was shot. Make it as close to stock specs as possible. Good luck.
Jason
[Modified by littlebluecrx, 6:21 PM 2/10/2003]
Old Feb 10, 2003 | 07:52 AM
badCRX's Avatar
New User
Were those times using the MT slicks? What wheels were you using as well?
Old Feb 10, 2003 | 08:43 AM
Robb's Avatar
Default Re: Caster setup for z10 (badCRX)
He was using M&H with Lenso 13x7.5
Old Feb 11, 2003 | 07:13 AM
earl's Avatar
Default Re: Caster setup for z10 (Robb)
What air pressure were you running?
portugino_69
Jul 5, 2008 05:35 PM
BoOsTiN Dc2
Sep 5, 2005 12:02 AM
b19coupe
Apr 9, 2005 04:31 PM
Incognito
Jun 11, 2002 12:41 PM
nighthunt6
Apr 26, 2002 04:37 AM
