muffler dimensions. ALL EG owners!
This is to all the EG owners here.
I am getting a custum exhaust put on and i need to know what dimension muffler to use. I am probably going with a magnaflow round body style muffler. Would would one with a 20 inch overall length, and a 14 inche body length fit correctly on an EG?
measure the length from the axle back and see if the the muffler will fit in there..they can always cut back the *in* piping to fit it in there..some car s they may have to mount the muffler at an angle...if u dont like doing it that way get a oval muffler with more in and out options..ull get the same performance
on my GS it was necessary to use an oval with a offset to offset in order to keep the bends to a minimum
magnaflow !!
magnaflow !!
I have a Magnaflow Oval on my hatch. It's on of the muffler and tip combo. 14 inch muffler and the tips are 6" long. It stick out from the bumper about 3-4" and looks like **** imo. If you want one to fit under the bumper is has to be a 4X9 oval body or a round (canister) body. I'm switching to a canister style.
ok, can somebody give me a link to a 4x9?
so you guys use the 4x9? I would assume that the inlet and outlet should both be in the middle, is that correct?
But it should be; all the mufflers I see on HT are center/center ones.
Actually the inlet and outlet should be offset and be on one side of the muffler for it to fit just like stock. I know this cuz I ordered a center/center inlet/outlet 4x9 magnaflow muffler and when i took it to the muffler shop the guy told me i couldn't use it. I know that he probably could have made it work, but it would not have sat exactly like stock. I know alot of people do use the center/center oval mufflers, but on the cars I have seen, the tip will not come out in the stock exhaust cut out on the rear bumper, or the muffler will have to be angled or tilted slightly.
roycivic92
Dec 14, 2008 12:22 PM
-[95cxhatch]-
16
May 15, 2007 06:49 AM
daNk9
Feb 7, 2004 01:10 PM
