adjusting the drivers door??
Old Feb 9, 2003 | 08:08 AM
andrewasf77's Avatar
Default adjusting the drivers door??
well as some of you know my R has a couple nice dents on the drivers side door. i was wondering if anyone knows how to adjust the door so that i seals better. during hard rain the car leaks like crazy. im sure there is a way to do this, just not sure how. thanks
andy
Old Feb 9, 2003 | 10:49 AM
Default Re: adjusting the drivers door?? (andrewasf77)
looking for a little help
Old Feb 9, 2003 | 01:45 PM
migs's Avatar
PM https://honda-tech.com/zerouser?cmd=...e&id=999299273
Arno should be able to help you out.
Old Feb 9, 2003 | 01:47 PM
JPP's Avatar
JPP
From what I just read in the Helm manual, you can adjust the door IN and OUT by loosening the door mounting bolts, and you can adjust the door foward/backward up/down by loosening the hinge mounting bolts. Unfortunatly I do not have scaning material to show you the graphics.
BTW you can also adjust the door catch In/Out up/down by loosening its mounting bolts
Old Feb 9, 2003 | 02:48 PM
anyone else have any input?
Old Feb 9, 2003 | 04:44 PM
mstewar's Avatar
ttt
my leak seems to be a result of the same problem.. i need to adjust it in i believe..
anyone have any more info on this?
Old Feb 9, 2003 | 04:48 PM
hungsteR's Avatar
Default Re: adjusting the drivers door?? (mstewar)
When your car's leak due to the door, where does the water collct at?
Old Feb 9, 2003 | 05:09 PM
mstewar's Avatar
Default Re: adjusting the drivers door?? (hungsteR)
mine collects in the floorboards on the driver's side.. which means I go through a lengthy drying process to stop mildewing everytime there is a hard rain..
Old Feb 9, 2003 | 05:48 PM
all over the drivers seat
hungsteR's Avatar
mine collects in the floorboards on the driver's side...
Does it collect under the driver's seat and the passenger foot rest area?
Old Feb 9, 2003 | 07:53 PM
Bbasso's Avatar
Are you sure the gaskets/ door seals are in good condition? Make sure that they are not torn or unclipped first before you go and start unbolting things
Old Feb 9, 2003 | 08:41 PM
Default Re: adjusting the drivers door?? (Bbasso)
i know that my gaskets arent in the best shape, but i wanted to try something for the meantime
ace8
Sep 18, 2009 08:09 PM
Lude@Heart
11
Jul 27, 2006 11:19 PM
itellyawhat
11
Feb 19, 2005 01:07 PM
acourt
Nov 27, 2004 05:38 PM
tha Big EZ
Dec 4, 2003 10:47 AM
