h22 a Accord Tachometer Problems...
Old Feb 9, 2003 | 07:55 AM
ihaterice's Avatar
Default h22 a Accord Tachometer Problems...
Is there anything in particular that you have to do to get the tachometer to work in a 94 accord with a 95 h22 swap in it? i know the prelude has the digital display while the accord has an analog display so does this cause any specific problems? any help would be appreciated, thanks
james
Old Feb 9, 2003 | 08:57 AM
Hondaaccordvtec's Avatar
Default Re: h22 a Accord Tachometer Problems... (ihaterice)
No, there is nothing unique you need to do in order to get the tach to work. The only problem will be your Accord tach has the wrong redline depicted on the stock gauge.
Old Feb 9, 2003 | 01:20 PM
KTeller8's Avatar
Default Re: h22 a Accord Tachometer Problems... (Hondaaccordvtec)
i agree. i have no problems with mine 96 h22 in 96 accord. the harness still run the same wires to the correct sensors. those sensor will run the signal to your tach.. its more of how its displayed. no different than buying an aftermarket digital display. or having one of them monster tachs.ya know??
Old Feb 10, 2003 | 04:27 AM
KGAccord's Avatar
Default Re: h22 a Accord Tachometer Problems... (KTeller8)
my only problem is the tach is off by more than is usual. at 7,900 the v-afc reads 7,300 when it should be around 7,500 on the v-afc.
the 6,200 redline doesn't matter cause when racing your shifting at 8k anyways.
Old Feb 11, 2003 | 11:27 AM
Drkaccrd's Avatar
Hey kteller8 do you have any problems with check engine lights, such as the evap canister code? Or any idle problems?
Old Feb 11, 2003 | 04:43 PM
AccSIR's Avatar
Default Re: h22 a Accord Tachometer Problems... (Drkaccrd)
iv noticed the same diference between the tach and the v-afc mine isnt as much though.
svasquez1982
Oct 17, 2011 01:40 PM
TwoKSiR
Sep 5, 2008 04:31 PM
95accordh22a
Feb 17, 2005 12:06 PM
Boosthead
Oct 25, 2002 09:46 AM
