WTF-missing motor mount bolt.
Old Feb 9, 2003 | 05:08 AM
97accordex's Avatar
Default WTF-missing motor mount bolt.
I recently removed the intake manifold on my F22B1 for re-conditioning etc, and found a couple of things that surprised/disturbed me.
1. A bolt from the rear engine mount was missing! This is the bolt that attaches the motor to the bracket. The rear engine mounting point was essentially floating! I am not sure how long it has been like that but I ordered a new bolt. This is something I never would have seen had I not removed the intake mani. Might be worth a look next time you do an oil change.
2. The EGR chamber was so full of soot that it must have been flowing less than 25% of original volume. I was getting a code 67 before I started the work and wonder if that was at related to it.
Was also wondering if anyone has any tips on mild porting/polishing of intake manifold and plenum. Those surfaces are so rough, they have the original casting surfaces. Can't get at most of it since there are so many bends etc. but can get at the parts near the ports.
Old Feb 9, 2003 | 08:59 AM
Hondaaccordvtec's Avatar
Default Re: WTF-missing motor mount bolt. (97accordex)
Send your IM out to be ported as well as your Throttle Body to be enlarged. You should get some great improvements with these mods.
Old Feb 9, 2003 | 11:31 AM
Ekasey's Avatar
Default Re: WTF-missing motor mount bolt. (Hondaaccordvtec)
well if you want just take a dremel and kind of grind away the casting flaws and yeah that motor mount bolt would be quite disturbing
Old Feb 9, 2003 | 12:34 PM
Chiovnidca's Avatar
Nope, low EGR flow will cause a code 80. Code 67 is usually a bad cat.
b16a2EBP
Mar 23, 2006 08:40 AM
george34
13
Feb 22, 2006 11:09 AM
mkazm83
Jan 28, 2006 04:46 PM
Ronin150
Nov 17, 2004 09:21 AM
DMF
Oct 13, 2003 06:25 AM
