Question.... the guy at the alignment shop said ?
Old Feb 9, 2003 | 02:46 AM
travytrav's Avatar
Default Question.... the guy at the alignment shop said ?
He said he would have to bend some bar on my spindle, to put on my springs and shocks. im going to do a 1.8in drop with some eibachs and tokico's... do you guys recommend that or should I get a camber kit... when they Bend that bar does it go out of alignment. let me know thanks ?
Old Feb 9, 2003 | 02:54 AM
97hb's Avatar
Default Re: Question.... the guy at the alignment shop said ? (huntagathera)
What??? Thats not right . You shouldn't have to bend anything for springs and shocks unless its bent in the first place, then you should just replace the part.
Old Feb 9, 2003 | 03:00 AM
travytrav's Avatar
Default Re: Question.... the guy at the alignment shop said ? (97hb)
I have a 99 civic sedan. (hx) they said in order to get the alignment at zero. they bend this little bar. I drift, so I hope it doesnt go all crazy.
Old Feb 9, 2003 | 03:04 AM
mycivicstoo(s)low's Avatar
you drift your civic?
EDIT:
[Modified by mycivicstooslow, 4:05 AM 2/9/2003]
Old Feb 9, 2003 | 03:09 AM
travytrav's Avatar
Fudge yeah............ march 2nd be there... http://www.driftshowoff.com
Drifting a ff is easier/harder then a fr car. its not as fun as a fr is but it works. I would like to get a hatchiroku, but I can maintain with the whip I got for right now.
Old Feb 9, 2003 | 03:15 AM
Well if it's something you enjoy, . As for your suspension, I don't think anything should be bent. I don't think your camber is supposed to be at exactly zero anyway.
89civicdx's Avatar
He MIGHT be talking about bending the knuckle...its like a cheaper way to get your camber back to spec. They take out the knuckle put in the vice and bend it until they get it back to 0 or wherever. Its done a lot in racing when you arent allowed to use aftermarket camber adujsters.
But if you are only doing a 1.8 drop I think you only need to worry about your toe settngs.
[Modified by 89civicdx, 4:16 AM 2/9/2003]
Old Feb 10, 2003 | 12:12 AM
travytrav's Avatar
You guys are awesome thanks!
sn00py415
May 17, 2007 12:20 PM
integraboi1010
Nov 30, 2004 03:59 PM
soul_urban
May 17, 2004 11:36 AM
brownman72000
Oct 29, 2002 10:52 PM
ArchAngel Sabastian
Oct 8, 2001 03:48 PM
