who has a'pexi vafc on their 4 cyl accord?
i recently found that about this so forgive me if this was last week's news... if you go to http://www.apexi-usa.com/tech.asp, it says:
Q. VAFC: Will the VAFC work on 4 cyl. Accords?
A. No. The VAFC will not work correctly on 4 cyl. Accord models. 4 cylinder Accords incorporate a slightly different method of VTEC control causing the engine to hesitate at approx. 5000 RPM when the VTEC engagement point is changed. The VTEC AFC will work correctly on 6 cyl. Accords.
Please double check our Documentation/ VAFC Updates page for the latest VAFC application charts.
i saw the hesitation at around 5000 rpm on my dyno graph so i rewired the vtec solenoid and vtm wire back to stock so that the vafc would run like a safc... but there is still hesitation on wot/full boost... like the car pulls but then it's struggling in the high end like there's a speed governor... more like a boost governor... any ideas..?? some say it could be spark plugs or distributor... i'm getting msd btm installed and car retuned monday-
I read that also, though the V-AFC works prefect on my 2000 accord F23.
Though make sure you have the Vtec engagment no higher then 3800 rpm
[Modified by 3700 Vtec, 11:52 PM 2/8/2003]
weird-i called a'pexi usa and they've confirmed the problem in detail... when i had the vafc when i was NA (intake and exhaust), everything "felt" okay... but with turbo i can feel the hesitation... niedejb, what is your lo to hi and hi to lo vtec setting..?
It's only really a problem on The F23 which has a variable engagement point vtec x-over. just don't have the vafc control the x-over and you will be fine.
lo-hi 3100
hi-lo 3200
Setting any higher just lost me power until engagement.
hi-lo 3200
The lowest it can go in other words.
Jweller, so the F23's have some type of i-vtec? Mine seems to be running fine.
I don't doubt it runs fine. most dynos I've seen don't start below 2000 - 2500 so you probably never see it, and if you are just putting around town, it's not really an issue. best way to tell is if when your motor switches to the high cam, you get that "mad crazy Vee-tech power yo". that pretty much means it is starving for air. when you switch to the high cam you suddenly get more air and boom, you make more power. The Accord is supposed to have a smooth x-over and even when it is pretty highly tuned, the stock cam will still be pretty smooth
the bump at 4500 is fuel related. the stock ECU fuel maps get more aggressive around that point.
the v-afc never worked right on the F22b1. it bogged down and ran rich. i called apexi about it and they said it's not been tested or approved for our cars, but it can work.
it works great on the h22 though.
It works fine on my 97 EX .. F22B1 here is my dyno ...
AccordExhange and I had a conversation the other day, I wonder if it is due to the fact that his car is auto .. hmm.
The Apexi VAFC did in fact work fine on my car. A 94 EX automatic. It controlled my vtec crossover point and worked flawlessly AFTER IT WAS HOOKED UP PROPERLY. When I went by Apexis wiring diagrams it did not work. I did some more research and found out the correct wat to wire it. The info is in the archives here on H-T. Just search VAFC in the Accord archives.
Heres an email I sent regarding the F22B SOHC VAFC install:
OK. All of these will be looking at the wires with the connectors in the
> ecu. The top will be the part with the push tab.
> The Red and orange both go to the yel/blk wire on the 32 P connector #11 top
> right corner.
> The Blk and Brn both go to the Blk wire just to the left of the #11 above.
> Note the Brn wire needs to be closer to the ECU.
> The Grn wire goes to the 32P connector Yel/Grn Wire #20. This is down one
> row and left 3 columns. It should be the one with nothing in the row above
> it (an empty spot).
> The grey wire goes to the 16P connector (the smallest) Red/Blk wire. In the
> top row all the way to the left.
> The Blue wire is not used
> The pink wire goes on the car side of the cut 32P connector #8 Grn/Yel wire.
> Its the wire two to the left of the Blk wire for the ground. The Purple
> wire goes on the ecu side of the same wire. Make sure they dont connect
> bypassing the VAFC.
> The White wire goes on the car side of the cut MAP sensor wire. This is on
> the 16P connector white/yellow wire two wires to the left of the Throttle
> Positioning Wire. The ecu side of the cut wire should get the yellow wire
> from the VAFC.
That's the info that I went by to install mine. The only thing different I did was I had to hook up the blue VTM wire. When it wasn't hooked up, I went into limp mode. Hook that wire up according to Apexi's diagram.
Edit: Thanks niedejb
[Modified by Stew Pidasso, 6:16 PM 2/10/2003]
Chubs
Apr 23, 2003 06:32 PM
accordexchange
Feb 4, 2003 03:18 PM
