b16 won't rev past 3krpm... why???
Old Feb 8, 2003 | 04:25 PM
joey1320's Avatar
Default b16 won't rev past 3krpm... why???
like the topic says. it's a friends car and he can't get it to go past 3k.
the motors is a b16a on a 93 hatch. he has checked everything plenty times and has come up with nothing.
for ecu he has the b16's and he also has a b18's which he has put on and the motor still starts...but same problem.
anybody has any idea what could it be?
he's going crazy over this sh@#!
looking for solutions before he does an insurance job...
Old Feb 8, 2003 | 04:52 PM
OBD1 Kenobi's Avatar
Default Re: b16 won't rev past 3krpm... why??? (joey1320)
Sounds like it is in limp mode due to an engine code or perhaps he has an auto ECU in it.
Old Feb 8, 2003 | 05:38 PM
wu tang's Avatar
Default Re: b16 won't rev past 3krpm... why??? (OBD1 Kenobi)
look at this ecu. it should blink 14 times. that means u have a bad idle air control valve. that is locatd at the back of the intake mani. replace that.
Old Feb 8, 2003 | 05:43 PM
b16powwer's Avatar
my b16 did that, your timing might be off.
Old Feb 8, 2003 | 06:07 PM
USDM 4G VTEC's Avatar
i can bet u he has a crankangle sensor code
code 4
and with that code the engine wont past reviong over 3-3.5 k rpms.. u gotta fix that first///
the first step it sot check the CKP sensor cables arent inverted
Old Feb 8, 2003 | 06:43 PM
I Gotta Question's Avatar
Default Re: b16 won't rev past 3krpm... why??? (JDM EF9)
When did it start screwin up? May have jumped the timing belt a couple of notches.
Old Feb 9, 2003 | 07:20 AM
joey1320's Avatar
Default Re: b16 won't rev past 3krpm... why??? (89_CRX_HF)
i tried getting a hold of my friend but his cell's not working, i printed the info so when i see him i'll give it to him.
thanks for the info...
Old Feb 9, 2003 | 07:30 AM
ricodemus's Avatar
that happened to me once for no reason, I just resetted the ecu. probably not your solution, but it worked for me.
Old Feb 9, 2003 | 09:05 AM
Camshaft's Avatar
Default Re: b16 won't rev past 3krpm... why??? (ricodemus)
The Ecu is in limp in mode.
Check then ecu for codes......
Repair codes...
or post what codes are displayed so we can help
What ecu PR3 or PW0 ?
Old Feb 9, 2003 | 09:08 AM
Jared's Avatar
replace the dist
Old Feb 9, 2003 | 09:35 AM
Frosty_spl's Avatar
Default Re: b16 won't rev past 3krpm... why??? (Jared)
mine did that out of the blue one day.
It went back to normal 5 minutes later after i cranked it up. It had a constant light, it didnt blink at all.
Old Feb 9, 2003 | 01:19 PM
Camshaft's Avatar
I would highly suggest finding the problem first before randomly buying parts and replacing it.
Unless you have a friend that will lend you some tester parts
paybac4223
Jun 28, 2004 06:00 PM
redzcstandardhatch
Jul 27, 2003 09:39 AM
wu tang
Jan 20, 2003 08:59 PM
White Lightnin
Jun 28, 2002 09:15 AM
si foo
May 19, 2002 08:03 AM
