Sensor in Cat Coverter?
Old Feb 8, 2003 | 03:07 PM
RallySportCivic's Avatar
Default Sensor in Cat Coverter?
I just got a new cat converter, and there is a threaded hole to put some kind of sensore in. My car now has strait pipe with no cat, and I need to put this new on on(long story). So on a 89 civic si, is there usually some kind of sensore in the cat converter that is screwed in to it?
Old Feb 8, 2003 | 03:11 PM
SIRX's Avatar
Default Re: Sensor in Cat Coverter? (RallySportCivic)
it's for an air pump or the 02 sensor. Alot of cars run them there. run down to where you bought it and buy a plug for it
Old Feb 8, 2003 | 08:39 PM
tominos's Avatar
for o2 sensor.
Old Feb 9, 2003 | 02:33 AM
katoeh2o's Avatar
Default Re: Sensor in Cat Coverter? (tominos)
use a spark plug non fouler. get the one that is the same size as you o2 sensor i think that is hat it is for . the non fouler will have a little hole in it, i just filled it with jb weld. hope that helps.
Old Feb 9, 2003 | 09:25 AM
Camshaft's Avatar
Depending on its location most likely its a O2 sensor hole.
Before and after its O2 sensor
hole in the middle its a air pump connection
You can plug it with a K&N O2 sensor plug or Walker Dynomax 02 sensor plug
good luck
kaka10
Nov 29, 2009 09:45 PM
amej8
May 28, 2008 02:34 PM
cubism
Welding / Fabrication
Dec 1, 2004 10:39 AM
R134
Aug 27, 2001 02:08 PM
