D16Z6 Swap List
Old Feb 8, 2003 | 02:18 PM
SteveeeO's Avatar
Default D16Z6 Swap List
Alright, I have looked over the search and all the info was scattered around and different things were said - I will be swapping into a 90 CRX Si, getting the motor from Nippon Motors
Just wanting to make a list for me and future people, here is what I have so far
92-95 Water Pump
92-95 Timing Belt
96-99 EX Intake Manifold (D16Y8-Not required)
92-95 Head Gasket
92-95 Intake Manifold Gasket
OBD1 Conversion
92-95 Spark Plugs
92-95 Spark Plug Wires
90 Si tranny
anyone know where to get a lightened flywheel? I can only find them for b series
let's get this post with all the info so it answers a lot of questions, I will be editing the post to add the information
Thanks
[Modified by SteveeeO, 8:44 PM 2/8/2003]
[Modified by SteveeeO, 8:48 PM 2/8/2003]
Old Feb 8, 2003 | 04:01 PM
Malgerus's Avatar
Default Re: D16Z6 Swap List (SteveeeO)
now my question is, what clutch should I use? Will the cable tranny work? what else should be replaced?
You'll use your 90 Si tranny. Buy the clutch for whatever flywheel you will use.
Old Feb 8, 2003 | 04:10 PM
Broken Gearbox's Avatar
Default Re: D16Z6 Swap List (Mr. S)
Get new Spark Plug Wires and new Spark Plugs
Old Feb 8, 2003 | 04:39 PM
ViperRedCRX's Avatar
92-95 Water Pump
92-95 Timing Belt
92-95 Head Gasket
MSD RPM Swtch - To activate VTEC
Thanks
nope...obd1 conversion is the only way to go
Old Feb 8, 2003 | 11:17 PM
BoostedED9's Avatar
Default Re: D16Z6 Swap List (ViperRedCRX)
all the sohc (d series) fidanza flywheels have the same part # from what i have seen so far.... great flywheel btw i got one in my car..
Old Feb 9, 2003 | 05:57 AM
SteveeeO's Avatar
Default Re: D16Z6 Swap List (BoostedED9)
how much does it weigh? (I will be going turbo in the future, so im not sure if I am going to get the lightened flywheel)
Old Feb 9, 2003 | 08:47 AM
BoostedED9's Avatar
i belive they are 7.5lbs
PZ
Dec 31, 2006 12:10 AM
AJxr
Oct 5, 2005 06:16 PM
cr00klyn718
Aug 19, 2004 05:45 PM
SteveeeO
20
May 19, 2003 01:07 PM
SteveeeO
11
Mar 19, 2003 01:44 PM
