tires for 99 coupe
Old Feb 8, 2003 | 01:21 PM
All_Lag's Avatar
Default tires for 99 coupe
I am looking for new wheels for my 99 coupe and i dont really know which tires will fit without rubbing or any other problems. I found a Tire/Wheel package I like and it comes with either (195/50/16) or (225/50/16) tires. My question is which of these will fit my car best without rubbing or any other problems
-Thanks in advance-
Old Feb 8, 2003 | 01:23 PM
rodrez.'s Avatar
Default Re: tires for 99 coupe (SlowSOHC)
-Thanks in advance-
I'm using 205/50/15's and they slightly rub (Azenis), I think the 225's would rub for sure on your car.
Old Feb 9, 2003 | 04:14 AM
All_Lag's Avatar
Default Re: tires for 99 coupe (rodrez)
Is your car lowered, if so how much?
Old Feb 9, 2003 | 07:35 AM
BIGPETE's Avatar
What sort of package are you looking at ? How much ?
I'm looking for a 16 " soon too.
Old Feb 9, 2003 | 08:30 AM
qcoffey's Avatar
I found a Tire/Wheel package I like and it comes with either (195/50/16) or (225/50/16) tires. My question is which of these will fit my car best without rubbing or any other problems. -Thanks in advance-
The answer to your question is, neither. Both of those tire sizes are incorrect for your vehicle. The overall diameter of each of those is to large. If you are going with a 16" wheel make sure you stick to a 205/45/16. This will keep your rolling diameter the same. Also, look at the width and offset of the wheel. You don't want to go any wider than 7" and stick with a 40 or higher offset. This way even when your car is slammed it won't rub.
Old Feb 9, 2003 | 09:15 AM
deepnite's Avatar
Default Re: tires for 99 coupe (qcoffey)
205/45/16 s would be the better fit there with a 40 offset ..this was on my 98 coupe
[Modified by deepnite, 6:16 PM 2/9/2003]
Old Feb 9, 2003 | 11:59 AM
All_Lag's Avatar
Default Re: tires for 99 coupe (BIGPETE)
http://www.wheelmax.com/Wheels/5zigen/5zigen.html
im planning on getting the Pro-N1 Black Racing wheels(in Black)
and they do come with 205/45/16 also, so this would be my best choice right?
Old Feb 9, 2003 | 06:38 PM
kommon_sense's Avatar
Correct, 204/45r16. I'm running a set of yokohama avids in 205/45r16. Not bad, but I'll probably get some falkens next time.
chillerice
Dec 27, 2014 11:23 PM
Msajr422
Jan 9, 2012 06:26 PM
pyork03
Feb 20, 2008 06:31 PM
RSX8600
17
May 30, 2004 07:29 AM
yodude
Aug 14, 2002 12:26 AM
