OBD1 question (CEL jumper)
Old Feb 8, 2003 | 11:56 AM
zCivic's Avatar
Default OBD1 question (CEL jumper)
Ok I've searched just need to know if this is correct. I'm making my OBD0 OBD1 harness in my spare time. Yeah, yeah, yeah I could buy one but I like the challenge. Well its almost done, just was wondering about the CEL jumper I connect pin C4 to B20 and then D22 to C14 those are the 2 I jump to check the codes correct?? Do I just run a toggel of these 2 and when off there open and when on there jump and will flash. Correct incorrect?? Also I need a few pins for the OBD1 harness think about 5 or 6 should cover me to be safe. If you can help with that also let me know. I feel like a noob asking these questions, heck I'm not even going to use the harness (I think)
Old Feb 8, 2003 | 01:21 PM
Malgerus's Avatar
Default Re: OBD1 question (zCivic)
Are you using storminmatt's guide? I did, and when I made my conversion harness it was easy to check the codes. You simply jump the service connector in the engine bay with a wire, and it'll flash the codes.
Old Feb 8, 2003 | 01:34 PM
zCivic's Avatar
Default Re: OBD1 question (Mr. S)
You have a 88-89 right?? Is this the same jumper that you use when you set the timing?? BTW this is the one I'm using http://www.geocities.com/kurtsi_on/. Think storminmatt copy and pasted it on a post I seen a while back
Old Feb 8, 2003 | 01:38 PM
zCivic's Avatar
yeah it was storminmatt just read and found out thats where this guy got it from, sorry storminmatt (whomever you are)
Old Feb 8, 2003 | 03:06 PM
Malgerus's Avatar
Yep. just jump it.
Old Feb 8, 2003 | 06:28 PM
zCivic's Avatar
Ok thanks always wondered about that and I know I heard someplace needed a toggle switch to activate it..... So Just connect everything plug it in and wire the Diz. Are there any other problems you've had. I may use it later on down the road never can tell, like I said I like the challenge. BTW I found a OBD0 harness and took the pins out of it for my missing ones looks like it should work, cross your fingers of course
Old Feb 8, 2003 | 10:32 PM
See Are X's Avatar
has anyone actually made an obd0-1 harness using these EXACT instructions??? cause on hasport, http://www.hasport.com/Tech/Wring/Co...onOBD-OBD1.htm , a couple of the pin locations are different...
for example, the hasport diagram shows B11(obd1 plug) goes to C1(obd0 plug)...and on that geocities site, it says, B11(obd1 plug) goes to B10(obd0 plug).
I would just like to know, which diagram can I rely on?
Old Feb 9, 2003 | 11:23 AM
See Are X's Avatar
Default Re: OBD1 question (See Are X)
up
Old Feb 9, 2003 | 01:30 PM
zCivic's Avatar
But on this wiring diagram the guy also says the on the Diz wiring that he did it the easiest way of matching colors thats more then likly why the pins are in different places because the wiring colors dont go together on the Diz because c11 is a CYP sensor and thats in the Diz. I think that hasport is going by sensors only and not by color also meaning when you rewire you diz you have to figure out what color goes where. I think storminmatt has the right idea on just matching colors no guess work here
Freemananana
22
Oct 20, 2013 03:01 PM
Tanked
Sep 10, 2012 03:30 PM
jdmdikk
Apr 15, 2009 07:55 AM
shaggyeg6si
Jun 28, 2008 08:30 PM
Bewkrazed
May 9, 2003 01:20 PM
