A few of Jotech's extra race parts...
Hey guys, cleaning up the shop and i've got a bunch of diffs and stuff for sale.
(1) New Pro Drive Spool for 92-96 Prelude - $495
(1) Used Pro Drive Spool for GSR/Type R - $325
(5) New Pro Drive Spools for GSR/Type R - $495/ea
(3) New OEM Type R LSD's - $650/ea
(1) New ATI Super Damper pulley for B series motors - $550
(2) New Lastest Version of Pro Drives 4.40 ring and pinion sets $1300/ea (these
are the newer version that won't break)
I've got a few other misc. other things, but I haven't had a chance to go through it all yet. IM me if you have any questions.
damn...I'm kinda thinking about this...
waht do you suggest tony? buy your spool or wait for a quiaffe?
those spools are highly reccommend for drag only i rather pass on it and get quaifes... even kenny uses the quaife ask art as well what he thinks but if you are on budget the pro drive spools will work
For a car that will be driven on the street at any point, I would recommend the quaiffe. The only downside to a spool at the track is if an axle breaks it will pull the car to the opposite side. If you run a spool I highly recommend you run a good set of axles. 75% of the racers out there run spools. Can't beat it if you're on a budget...
yeah, I know the outcome of a broken axle with a spool already
I'm getting rid of my stage 3 DSS adn getting stage 5...
one question
most axles will break off they line right? So it shouldn't be that bad will it? Have you guys ever experienced a broken axle towards teh end of the track?
one question
one question
one question
one question
I don't know anyone who's actually found the "limits" of the type r diff. What kind of power do you plan to make and what size slicks do you plan to run?
It should be good enough, but i'm not promising anything
Has anyone on here broken one? What conditions did they break in? I'm curious too.
Bump Tony
, one of the few who has something worth buying.
I have seen 600hp on the type-R trans.. i think you should remember that.. TEXAS needed a trans for someone( no names wil lbe mentioned).. 2 years ago..??
[Modified by camp1320.com, 7:27 PM 2/12/2003]
, one of the few who has something worth buying.I have seen 600hp on the type-R trans.. i think you should remember that.. TEXAS needed a trans for someone( no names wil lbe mentioned).. 2 years ago..??
