need help w/ obd1 conversion in ef [plz help, search did nothing]
ok, now I'm in round 2 of this thing - I need some help getting the 8-pin connector in the driver side wired, what wires go in and out??
also what do I do with the B15 and b17 pins on the obd0 plug??? they're both ignition output signals, the obd1 uses pin a21 for the icm [ignitor?]
one of the charts I saw said run a22 to the b17 pin, but a22 [obd1] has no function? I need to get my friend's car started like yesterday, can someone help 'splain it to me, thanks much appreciated.
-l8r
[Modified by Death Scythe, 9:19 AM 2/8/2003]
-l8r
Dont know if this will help or not...
http://www.thezcresource.com/html/wiring.html
are you talking about the connector with the yel/blk wires with the cap on it? if so you will have one wire that goes to it that came fom the injector resistor. 4 wires that will go to your injectors and one wire that providees power for the heated o2. all 6 of these wires should be yel/blk.
Pin B17 will go to pin A22 on the OBD1 ecu. The other end of that wire should go to the yel/grn wire on the distributor. B15 goes to A21 on the OBD1 side and I am pretty sure that that wire goes to the white distributor wire.
Andy
Andy
Andy
Andy
SLURS
11
Jan 23, 2009 09:17 AM
Fleas_Ef
Jul 2, 2005 04:13 PM
gocivicgo
Aug 7, 2003 08:05 AM
