Will these brakes work on my eg?
I have everything needed to do the rear disc swap but im not sure if it will work on my car. all the parts i have are from a 93 teg(some tell me only 94+ will work), can anyone clear this up?
I believe they will work... I know the front ones will work because I am debating buying Brembo Rotors, and the 91-93 (I believe) Integra has the same front brakes at least as the 94-01, so I would venture a guess that they are the same. Sorry I figured I'd through that out since you haven't gotten many replies.
Scott
Scott
Scott
Scott
3rd gen Integra rear discs work with the "EF" Civics/CRX, not the "EG" Civics. All the 2nd/3rd gen 'tegs and "EF" Civics/CRX use pretty much the same rear trailing arms. 4th gen 'tegs and 5th gen Civics use pretty much the same rear trailing arm.
*EDIT* I just re-read what I posted and it looks mad confusing. Basically what I'm saying is no they won't work. If you had an 88-91 Civic/CRX, then they would be perfect.
[Modified by Milano_EH3, 4:11 PM 2/13/2003]
http://photos.yahoo.com/bc/slowcivic...&.src=ph&.view=
pics there...they were the rear from a 91 teg....
Ah, just goes to show you how much our parts are interchangable. I would still much rather have the rear setup from a '94-'00 Integra, because the suspensions are nearly identical. But, if those work than rock on.
I just did a search and found this.
[Modified by Milano_EH3, 6:11 PM 2/13/2003]
92ehatch
Nov 10, 2005 01:02 PM
b18bcivic
Dec 25, 2003 04:04 PM
