Can anyone give a review of GSR Bilsteins?
Old Feb 7, 2003 | 06:30 PM
lopey's Avatar
Default Can anyone give a review of GSR Bilsteins?
Hey all, I was thinking about picking up a set of Bilstein shocks for my gsr and was wondering if any of you have had any first hand experience. I am lookin for a pretty firm ride but don't want to shell out the cash for a full coil over system. (saving for lsd tranny w/4.785fd )
Old Feb 7, 2003 | 06:43 PM
stegs's Avatar
Default Re: Can anyone give a review of GSR Bilsteins? (lopey)
bilsteins, = pricey. Many like koni's. Are you lowering it? The koni's have an adjustable perch so you can go lower if desired.
Also don't think the bilsteins are adjustable. Big benefit of the koni's and others.
Bilsteins = BMW nuff said
Old Feb 7, 2003 | 06:44 PM
stegs's Avatar
Default Re: Can anyone give a review of GSR Bilsteins? (stegs)
also the koni's can be had for a little over 100 scratch a piece
Old Feb 7, 2003 | 06:46 PM
lopey's Avatar
Koni's are more expensive than Bilsteins.
Old Feb 7, 2003 | 07:28 PM
Pat's Avatar
Pat
Bilsteins are great if you don't need much adjustability. I run them on my teg, very good ride and good match for my H&R OEs
Old Feb 7, 2003 | 07:33 PM
Tweakmeister's Avatar
If you want the "sporty" Bilsteins, then you'll need to change out your rear lca's. The Bilstein SP model is only compatible with the TypeR rear lca.
There's a great Koni vs. Bilstein SP discussion in the Tech forum. Basically the Koni Yellows are a little better, plus you get adjustability with them.
Old Feb 8, 2003 | 05:48 AM
INTEGRAMIKE's Avatar
Default Re: Can anyone give a review of GSR Bilsteins? (Tweakmeister)
I run bilistein shocks on my car, but they are threaded shocks. I got them from neuspeed for 800$ they were 1600 for the set. They work very good I would probably rebuild them before I bought different ones. Either way you go if its bilistein or koni you will be getting good stuff. My car is pretty stiff without any other suspension upgrades.
[Modified by INTEGRAMIKE, 2:49 PM 2/8/2003]
PURPLERANGER
Suspension & Brakes
Jun 20, 2013 09:56 AM
ftwlucky13
Suspension & Brakes
21
Apr 5, 2005 01:13 PM
AznInvasion
Mar 29, 2004 02:24 PM
cichlid
Mar 17, 2003 05:30 PM
shattergsr
Oct 22, 2002 02:25 PM
