Mid Swap Help!!! b18b in EK hatch
Old Feb 7, 2003 | 06:20 PM
civicrtype's Avatar
Default Mid Swap Help!!! b18b in EK hatch
K everything is going great and swap is almost done just got a few questions its a 99 LS obd2 going into my obd2 civic using my dx harness:
1) Old Passenger side axle won't come out from the Hub side, I got the Nut out already and I tapped it lightly with a hammer, even used a pry bar wont come out.
2) Do I need to repin anything on the ECU
3) I got brand new LS axles but they got the ABS rings on em do I need to remove em? Or can just slap em on there?
Thanks in advance. Gonna finish this up tomorrow so I need help
Old Feb 7, 2003 | 06:26 PM
VTECVillain's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (civicrtype)
The axles tend to get rusted inside of the hub splines. Make sure to remove the tranny side first if you haven't already and then pound it out with a hammer. Spray some WD40 inside to loosen it up some.
Old Feb 7, 2003 | 06:37 PM
civicrtype's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (VTECVillain)
I did that its removed from the tranny side already. The driver side came out of the hub wit no problems. Ive soaked it like crazy wit PB blaster and **** still wont come out. I've hit it so hard that the axle is starting to mushroom. I dont care bout the axle just need to get it out!!! Thanks for the reply though.
Old Feb 7, 2003 | 07:16 PM
civicrtype's Avatar
Anyone else can help!!!!!
Old Feb 7, 2003 | 07:19 PM
pennies_hatchie's Avatar
i just pounded the crap out of mines...
Old Feb 7, 2003 | 07:22 PM
function83's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (pennies_hatchie)
did you lift the ball joint off the lower control arm?
if u did just pound the axle out, it should come out.
wiring info: http://tech.hybridgarage.com/tech/6gtech/index.html
leave the abs rings on your new axles.
[Modified by djhatch, 4:24 AM 2/8/2003]
Old Feb 7, 2003 | 08:01 PM
civicrtype's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (djhatch)
Thanks for the help fellas, ya i remove the ball joint and the fork from the suspension and i beat the **** out of it, guess gotta beat it up some more.........time for the SLEDGE hammer
Old Feb 8, 2003 | 02:20 AM
BackSideSA's Avatar
you need to take off the ABS rings because your car dont have ABS. use a flat head and a hammer and tap it off. i did that when i put new axles in.
your stock harness should work, my 98 LS motor plugged right is but i used an OBD1 ecu to make it work
pound the **** out of your axles to break em loose. WD40 alwasy help, spray and let soak
Old Feb 8, 2003 | 06:28 AM
FifthGearOnline's Avatar
how much did your swap cost and where did you get it from?
i want to do an LS swap this summer
Old Feb 8, 2003 | 07:30 AM
civicrtype's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (FifthGearOnline)
I peiced it out so it took a while like a month or so just to get the parts but I spent about $1000-1100 for full swap. Its 99 B18b. I am in NYC and there are alot of LS motors around here going for real cheap, I've seen OBD1 b18b's go for like $800-900 for full swap. Thanks for the reply fellas wish me luck gonna take the Sledge hammer to it today. LOL. Lata.
Old Feb 8, 2003 | 09:26 AM
DarkSol97's Avatar
A little warning about using the sledge hammer. Be very careful not to "mushroom" the end of that axle. You may flatten it to a point where it cannot slide through the hub. The same thing happened to me so I used a grinder to grind off the part that was "mushroomed". Well, goodluck
Old Feb 8, 2003 | 11:09 AM
civicrtype's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (DarkSol97)
thanks i am already starting to mushroom it, swap should be done by tomorrow only got a chance to work on it today for like 2hours. Kinda hard right now workin outside in NYC cause its 30 Degrees out here wit about 2-4inches of snow still on the ground......................talk about dedicated right? Lol? I need my car!!!!!!!!
Old Feb 8, 2003 | 12:45 PM
Foozball26's Avatar
to get the axle out get a beefy scredriver and something along that lines, hammer the **** out of the screwdriver, thats what I do do I dont hit the wheel studs
Old Feb 8, 2003 | 04:03 PM
i would go to new yawk and get one NOW if me and my bro had some time off!!!!
Old Feb 8, 2003 | 05:22 PM
97hb's Avatar
Don't forget to repin a12 and a14. What year is the car??? If it is 96-98 cx or dx you will throw code 91. All ex 96-00 or 99-00 dx or cx will not have this problem. It is because the car is not wired for the ptank sensor in the gas tank. You can also use any 96 ls ecu or any jdm ls ecu and not throw the code.
Old Feb 8, 2003 | 05:28 PM
civicrtype's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (97hb)
Its a 98 Cx so where do I repin a12 and a14 to? Or do I do a12 TO a14? And how can I prevent throwing a code? I am using a 98LS obd2 ECU.
Old Feb 8, 2003 | 07:16 PM
97hb's Avatar
Yes you will throw code 91. You need to switch a12 and a14 on the ecu side. Might be the other way around, regardless one has a wire going into it the other doesn't. Just switch position.
Old Feb 8, 2003 | 08:03 PM
civicrtype's Avatar
so if i switch it then it wont throw a code anymore?
Old Feb 8, 2003 | 09:53 PM
97hb's Avatar
You will still throw a code. If you switch the wire then you will not throw code 14 witch is the iacv. If you do not switch the wire the car will not idle when cold. Only way to get rid of the code 91 is get a 96 LS ecu, any LS jdm ecu, or get a new gas tank with a ptank sensor in it and a new evaporative canister with the purge valve in it.
Old Feb 8, 2003 | 09:59 PM
deviant1's Avatar
if you use a obd2 LS ecu it will still throw the code? what do you mean repin a12 and a14? you repin on the LS ecu correct? you use the LS axles in this swap right?
Old Feb 8, 2003 | 10:46 PM
BackSideSA's Avatar
**** my 98 B18B1 complete swap with install cost me 2200. i got some free Si seats....woohoo anybody want to buy them?
Old Feb 8, 2003 | 10:57 PM
YumVTEC's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (HybridHackBatch)
if you use 99+ integra ecu in the car it will throw a code for fuel tank pressure sensor, which did not exist on 94-98 integras. IAC wiring at the ECU is the only thing that needs to be changed if you're using your stock civic harness on the motor. good luck.
Old Feb 8, 2003 | 11:55 PM
deviant1's Avatar
Default Re: Mid Swap Help!!! b18b in EK hatch (YumVTEC)
if its 99+ only, then how come 97 hb has a 98 ls swap and he has the code? also, how do you do the wiring at the ecu? repin or move or whatever. how do you actually do that? and this is on the LS ecu correct?
Old Feb 8, 2003 | 11:58 PM
97hb's Avatar
I have a 98 and it throws the code. This code is non-existent on any jdm obd2 ecu.
Old Feb 9, 2003 | 12:02 AM
civicrtype's Avatar
K so how do I do this? I am using the stock dx harness wit a 98 LS ecu. LMK. Thanks.
