injector size for Hf crx And SI crx
Old Feb 7, 2003 | 06:06 PM
333's Avatar
333
Default injector size for Hf crx And SI crx
Does anybody know the injector sizes on the hf motor that is rated at 60 hp and does anybody know the size of the injector in the SI crx rated at 108 hp motor. I put in my old 240 cc injectors from my b16a. Just wondering if the SI injectors are also 240cc. Or are the hf injectors lower like 125cc. Thanks for your help.
I need to know because I want to turbocharge the HF motor. I have it set up, just want to see if I'm in the right direction for the size injectors I need. I know its a waste of time and I don't care I'm not going for power, or anything. Just want to turbo charge every car I have. Ford escape V6 is next.
Old Feb 7, 2003 | 06:17 PM
333's Avatar
333
Default Re: injector size for Hf crx And SI crx (333)
sorry about the double post.
Old Feb 7, 2003 | 06:26 PM
spettinger's Avatar
you plan to turbo a ford escape? i hope you can afford the payments (unless you have already paid it off) and then some headaches for tuning. i guess i just don't see the point, it is a family mini suv, and it makes sense to have it around when the other cars are broken and you need to go to the parts store.
Old Feb 7, 2003 | 06:54 PM
zCivic's Avatar
Default Re: injector size for Hf crx And SI crx (2ndhandCRX)
All of the injectors are the same for most hondas 240cc. The only ones higher rated are the prelude V-tecs OBD2 prelude injectors are 290cc. And the ODB1 are 345cc. OBD1 are plug and play the OBD2 you need to remove the injector resistor box. Congrats your the 500th post
[Modified by zCivic, 10:55 PM 2/7/2003]
Old Feb 8, 2003 | 01:29 PM
333's Avatar
333
Why not Keene Bell makes a supercharger for it, puts out 220 to all 4 wheels. Not bad for a 3500lbs trunk that stock does 16 in a 1/4. Plobably do a 14 if it hooks up.Stock torque and hp is 200. 160-150 to the wheels.
sporkcrx
Oct 21, 2006 01:07 PM
SOHCrx
Nov 27, 2003 07:39 AM
333
Feb 7, 2003 06:16 PM
Crxfanatic15
10
Jan 16, 2003 10:49 PM
1990hondaHF
Jul 23, 2002 12:50 AM
