Putting in the B20 soon some questions
Old Feb 7, 2003 | 04:56 PM
Blaze45's Avatar
Brrraaaap!
Default Putting in the B20 soon some questions
Heres what i got
b20 (duh)
LS tranny
ss header
90 teg axles
hasport shiftlinkage
LS ecu
LS Dizzy
mounts is what im waitin on
soon to have clutch & pp (buyin as we speak)
What else do I need? Im keeping the stock fuel setup (injectors)
that is obd2 cause Im goona wire em up to work.
I was thinkin about gettin a FPR but do I really need to?
Do I need a mount on the drivers side to match up with HASPORTs
mounts? I've herd that you need a different one. Anything else that I might need?
It doesnt seem right= I've almost got all the parts for the swap!
Unless Im missing something
Thanks
Blaze
Old Feb 7, 2003 | 05:31 PM
SuperJay's Avatar
Default Re: Putting in the B20 soon some questions (Blaze45)
you'll need injectors from a non-obd honda, I think the B20 has a taller IM so I would just swap it with a 90-91 Ls IM and call it a day although I heard those IM's suck. If your ordering a mount kit, use all the mounts that come with it, you'll need it.
Old Feb 7, 2003 | 05:52 PM
CHRIS 1.8's Avatar
http://www.b20vtec.com
Old Feb 7, 2003 | 05:56 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Putting in the B20 soon some questions (CHRIS 1.8)
I plan on keepin it obd2 injectors (c my post in tech) anyways I got the JDM B20B which comes w/ the LS style IM. Any other lil things that I might forget?
Blaze
Old Feb 7, 2003 | 06:50 PM
Blaze45's Avatar
Brrraaaap!
anyone else think i need anything else?
Blaze
Old Feb 7, 2003 | 08:15 PM
crooked muffler's Avatar
nah swap it and tell us how it goes
u stayin NA or turbo
Old Feb 7, 2003 | 08:20 PM
PhatOptimo's Avatar
Default Re: Putting in the B20 soon some questions (anti-ricecake)
The drivers side block mount (cast) on the B20 will not bolt up to an aftermarket MM kit. You need the DS block mount off a B16a.
[Modified by Phat_Optimo, 11:21 PM 2/7/2003]
Old Feb 8, 2003 | 12:04 AM
Brad's Avatar
You may need an intermediate shaft, flywheel, and maybe a b16/18 crank pulley so it won't overdrive the alternator.
[Modified by Brad, 1:04 AM 2/8/2003]
Old Feb 8, 2003 | 12:59 AM
OBD1 Kenobi's Avatar
Default Re: Putting in the B20 soon some questions (Brad)
Have you ordered mounts yet? My mounts have been tested in a CR-VTEC 89 EF hatch with 55 shot nitrous. The car has been run rather hard for 25,000 miles and still running strong. The mounts can take the torque.
Old Feb 8, 2003 | 10:02 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Putting in the B20 soon some questions (OBD1 Kenobi)
I plan on boosting to 12psi w/ 550cc injectors and Zdyne standalone. When the sleeves crack I'm going to rebuild it. hehe. About the FPR> do I need one? I'll be running the RR4 ECU which has fuel maps for a 1.8. E-mail me at extremeist45@hotmail.com with pictures of the mounts how much do they run?
Blaze
[Modified by Blaze45, 7:03 PM 2/8/2003]
jrsh0526
Dec 31, 2013 06:41 PM
fin781
Feb 27, 2008 04:59 PM
danny_ha
Aug 28, 2006 07:59 PM
mooseknuckle
Nov 21, 2003 04:53 PM
The Brown Kid
18
Dec 27, 2001 08:12 AM
