Water in Headlights/Taillights
Old Feb 7, 2003 | 02:32 PM
white95's Avatar
Default Water in Headlights/Taillights
I have stock headlights and taillights for my '95 GS-R, and was wondering if anyone knew of a fix to the problem. They have never been removed to my knowledge, but condesation it built up on the lens. Help?
Old Feb 7, 2003 | 02:48 PM
EL Vap133's Avatar
Default Re: Water in Headlights/Taillights (white95)
checks for cracks or separations, if you see any use some silicone to seal it...
Old Feb 7, 2003 | 05:10 PM
SMZ GSR's Avatar
common problem in integras...if your actual lenses are ok, pull out the lights and check the seals. for the headlights do a search for "baking headlights" and someone made a thread about breaking up the seal to re-do it.
Old Feb 7, 2003 | 05:36 PM
white95's Avatar
Default Re: Water in Headlights/Taillights (SMZ GSR)
I am posting this on behalf of a friend, it isnt actually mine...
I can bake them no problem, did some work on my Accord's Tails like that, fixing to do the Blackhousing heads...
Before I dive in on the 'Tegs front lights, is there anything I should know that isnt in the Haynes manual? Do the seals tear easily, any common problems getting them back in? Never done this work on anything but my Honda...
and thanks for the help..
Old Feb 7, 2003 | 05:41 PM
ragejed's Avatar
As for the taillights. The rear tail light gaskets go bad over time. You need to pull off the tail lights, let them dry, replace gasket, and install
Check my sig, and IM me. I make tailight gaskets
TheMoogly
Honda Civic (2001 - 2005)
11
May 13, 2007 11:25 AM
SIcivicHATCH
Jan 13, 2005 05:57 AM
jay_96teg
Dec 14, 2004 09:57 PM
Scartissue
Nov 12, 2004 11:01 AM
b18bme
Sep 18, 2004 07:13 AM
