86-89 integra injectors
Are these the same injectors as other civic and teg obd0 injectors. I need mpfi injectors for a swap and can only find some out of 88teg. will they work with crx si fuel rail and intake? thanks
From: the asshole of america..., upstate new york, USA
i would believe that they are the same 240cc injectors as in the si. check www.hondaautomotiveparts.com , www.acuraautomotiveparts.org , or even www.autozone.com and check the part numbers to see if they are the same.
