DEL SOLS...Are they really that lightweight?
Hey, i was just wondering if the popularity about a del sols weight is really that much of an advantage over domestics and even other imports, does anybody have comparisons in weight to other cars such as civics? thanks.
No. Convertibles are usually about the same as their counterparts simply because companies reinforce the frame of the car in case it's rolled.
Del Sol's are heavier then most other civics..
https://honda-tech.com/zerothread?id=150315
That thread covered most stock weights.
.brad is right, everypne thinks the sol is heavy but they are about the same whaight as a stock hatch. and lets not turn this into the "can a del sol be fast" thread. thanks
Only exception is a 94-95 Si Hatch. They are pigs and probably heavier than a delsol. Heavier with logic above = the same in reality.
Del Sol Si: 2396 lb, Civic Si hatchback: 2326lbs
Del Sol S: 2277 lb, Civic dx hatchback: 2178 lb
Civic vx & cx hatchback: 2094 lb
[Modified by starang, 3:11 PM 2/7/2003]
oh no not this one again here comes a flame fest if you want honest awnsers just look them up
here i did it for you http://www.wabe.net/silum/97DelSolSpecs.html
