Is bigger better ?
Old Feb 7, 2003 | 12:50 PM
binkster's Avatar
Default Is bigger better ?
Im talking about Intakes. I used to have a 3" ractive intake, when I installed it the car seemed to bog down real bad in the low RPM's. I just swithed to a 2.5" Intake and the car seems to get up and go.. its alot more peppy.. Why is this, I would have thought that the more air the better.
Old Feb 7, 2003 | 12:59 PM
vivid02's Avatar
Default Re: Is bigger better ? (binkster)
It is the pressure at which the motor takes in the air. Imagine a water going thru a big *** hose. Now imagine the same amount of water going thru a little straw......more pressure. Something like that. Air is not really pressurized though.
Old Feb 7, 2003 | 01:16 PM
owen_the_soyboy's Avatar
generally... bigger intakes will slow throttle response.
that is the lagging feeling you are noticing.
give and take, that how it goes.
Old Feb 7, 2003 | 01:18 PM
.brad's Avatar
25 Year Member
Depends on which hole you're going to stick it in.
In the end you're limited by your intake manifold so keep that in mind. If you got a larger than normal one at least you would know your car is breathing the best that it can.
Old Feb 7, 2003 | 01:21 PM
cormegga
Guest
Posts: n/a
Yea we know your talking about intakes Chester.j/k
Old Feb 7, 2003 | 01:28 PM
euclid's Avatar
Default Re: Is bigger better ? (cormegga)
you may loose low-end alittle but your top end will improve with a bigger intake i beiielve, same priciple as an aftermarket exhaust imo
Old Feb 7, 2003 | 01:34 PM
Vspec Sol's Avatar
Default Re: Is bigger better ? (euclid)
You would gain substantially at top end and even more with a bored throtle body and intake manifold, but you need to consider what you have on your and if it has enough power to take in all that air otherwise you do create a big lag on bottom end and it becomes annoying on street driving. Without work on your engine, you're better off with 2.5.
Tegraracer90
Honda Civic (2001 - 2005)
12
Mar 17, 2008 11:56 AM
allmotorkilla03
Oct 28, 2007 03:36 PM
integracura
Jan 18, 2006 07:03 PM
lke2drvgsr
Jul 9, 2004 02:18 PM
