do STOCK cams ever wear out?
Old Feb 7, 2003 | 11:55 AM
keebler65's Avatar
Default do STOCK cams ever wear out?
assuming proper oil change intervals, if i'm buying a set of used cams, do i need to worry about any type of wear factor? if theres a 100,000 miles on them, will they go for another 100,000 typically?
thankyou
kevin
Old Mar 3, 2003 | 05:05 AM
Charlie Moua's Avatar
Default Re: do STOCK cams ever wear out? (keebler65)
ttt
Old Mar 3, 2003 | 05:10 AM
92sleepR's Avatar
New User
With regular oil changes and valve adjustments and assuming you have the stock valve springs I have never heard of them wearing out. Look at the lobes. If there are any scratches or odd wear patterns dont get them.
Mike
Old Mar 4, 2003 | 07:36 PM
Quick 200k Mile Motor's Avatar
From taking apart high mileage heads, I'd say most likely the rocker & cam holder surfaces wear out faster than the cam lobes. There are differences in hardness between the parts. The stock billet steel cams are certainly the hardest!
Old Mar 4, 2003 | 07:57 PM
V3locity's Avatar
Default Re: do STOCK cams ever wear out? (Quick 200k Mile Motor)
If they're in good shape don't worry about it, use 'em.
88samurai88
May 1, 2017 05:05 PM
Sabres_e
21
May 15, 2010 12:50 PM
threehonda
K Series
Dec 20, 2009 06:37 PM
kulo
Dec 7, 2009 09:23 AM
Floyd
Jun 17, 2002 09:35 AM
