weird ? about rear seatbelt
one of my rear seatbelt buckles is hiding under the hole. I don't know how it got under but it is and i have a hard time getting it out. I tried putting the "male" part of the seatbelt in there so maybe it might "connect" with the buckle, but it won't seem to reach. Do I have to take apart the rear seat?
if you do have to pull out the rear seat, it's not hard at all. just pull out the two plastic clips on each side of the back piece. once those are out, slide the back pieces towards the side of the car and pull them out. then you'll see the one bolt holding the bottom piece of the seat in. after you take that out, you should be able to lift up the rear portion of the bottom piece enough to feed the seatbelt back up through the slot. hope this helps...
-tony
-tony
