zc swap in crx
Old Feb 7, 2003 | 09:16 AM
nsxblueteg's Avatar
Default zc swap in crx
hey guys i am about to do a zc swap in a crx and the guy i am doing it for is wondering if the ecu out of a first gen integra will work since the zc is almost the same? does anyone know???? thanks again
Old Feb 7, 2003 | 09:27 AM
thaiphob's Avatar
Nikon!!!
Default Re: zc swap in crx (nsxblueteg)
the ecu will work, but it will make your car run rich. id say go with the si ecu.
Old Feb 7, 2003 | 09:43 AM
G a b e's Avatar
Banned
Default Re: zc swap in crx (thaiphob)
Ths si ECU is for a single cam... I have heard many people say that the difference in performance is quite noticeabel going to a ZC ecu.
A first gen integra ECU will work, but it has to be from an 88-89. The 86-87's do not work, for a reason which I have forgot.
Old Feb 21, 2003 | 09:56 PM
Fa-Q Racing's Avatar
I have a ZC in my 1991 Si CRX. It runs great, and gets down the road. Use the Si Ecu.
Old Feb 22, 2003 | 01:05 PM
blackZC (W)
Guest
Posts: n/a
Default Re: zc swap in crx (Fa-qracing1991)
i had a 89 teg ECU in my ZC .its seemed to run better ..plus you can rev it on out , that Si will cut in way early..
try both, i noticed a jump in power at 4000 RPM with my TEG ECU ..the Si did nothing
h22_crx
Aug 16, 2005 07:31 AM
90ED9
Jul 26, 2004 12:28 PM
muskrat
Oct 10, 2002 07:09 PM
cr-x si
Aug 6, 2002 04:03 AM
REDBARON
Oct 15, 2001 06:21 PM
