Yes another valve adjustment question...
But it should be easy to answer.....
After Cylinder#1 is at TDC I have to turn the crank nut 90deg. counter clockwise in order for #3 to be TDC, then another 90deg. for #2....etc....? Is this correct? Muchos gracias....
2. turn crank counterclockwise until the cam gears turn 90 degrees (the box/whatever on the opposite of the exh "UP" side of the cam gears will line up with the "UP" mark on the int gear).
3. turn crank CCW until cam gears turn 90 degress again. the bottom "box" will now be up and the side marks should line up.
4. Turn crank CCW again until cam gears turn 90 degrees. Exh "UP" mark will line up witht he "box" on the "bottom" of the Int gear.
the order is 1, 3 , 4 , 2 when you turn the crank 90 degree each time
Nevermind, you're right
[Modified by OG Bizzle, 11:18 AM 2/7/2003]
Tommy_Gunns
Aug 23, 2002 03:07 PM
Black R
Jul 20, 2002 10:31 PM
