for sale misc
jdm 4 door integra rear seats
jdm 4 door integra door panels
jdm integra cluster
brand new ctr cams
98 and 2000 itr cams
itr intake manfiold w/tb and all sensors
98 jdm itr fuel rail w/injectors
98 jdm itr tb
97 gsr pistons w/rods
2 gsr crankshafts
1 b16 2000 si crankshaft
b16 2000 si pistons w/rods
obd1 gsr intake manifold
obd0 b16 intake manifold
sohc vtec 00 ex intake manifold
sohc vtec 95 ex/si intake manifold
front mudflaps off 94 civic
front mudflaps off 00 civic si
parting out delsol interior.
black on black delsol seats driverside has hole on bolster. pass. side has cig burn but not noticeable due to color.
obd0 b16 stock cams
itr stock cam gears
94 gsr stock strut bar will fit 92-00 civics
94-00 integra climate control.
no name strut bar will fit 94-00 integ and 92-00 civics
2 93 gsr rims w/tires but need to be replaced
b series shiftlinkage
b series mounts
obd1 gsr dist.
obd2 gsr dist
obd2 engine harness
obd1 Ls harness
del sol rear window
brake booster and master cylinder off 95 delsol
powersteering rack of 95 delsol
windshield wiper motor
rear trunk carpet
rear trunk shocks
front swaybar setup from 95 delsol si
del sol black dash
del sol door sills
del sol rear disk brakes
del sol gas tank cover
del sol prop valve
power steering reservoir,wiring,hoses should fit 92-00 civics
front brake setup
misc mouldings
misc plastics off delsol
fuel pump
d series mounts
d series shift linkage
stock gsr shifter
auto to manual swap parts for d series
auto to manual swap parts for b series
jdm integra cluster
brand new ctr cams
98 jdm itr tb
2 gsr crankshafts
obd0 b16 stock cams
itr stock cam gears
b series mounts
obd1 gsr dist.
obd2 gsr dist
obd2 engine harness
obd1 Ls harness
del sol rear window
rear trunk carpet
rear trunk shocks
del sol black dash
del sol door sills
del sol prop valve
front brake setup
misc mouldings
fuel pump
d series mounts
stock gsr shifter
