squeaking sound
Old Feb 6, 2003 | 08:32 PM
00fbp's Avatar
Default squeaking sound
as i was going home tonight i noticed that my front right wheel has this squeaking sound when i turn the wheel. what do you guys think is causing this? i never noticed it before. oh yeah i have coilovers, could it be the coils making that noise? any help would be great. thanx
[Modified by 00fbp, 9:36 PM 2/6/2003]
Old Feb 6, 2003 | 08:39 PM
ace1875's Avatar
Default Re: squeaking sound (00fbp)
It could be your brakes early warning, cause i have seen some brakes only squeak when turning.... how many miles has it been since you replaced your brakes?
Old Feb 6, 2003 | 08:42 PM
00fbp's Avatar
Default Re: squeaking sound (ace1875)
brakes are new, not even 4000 miles on them. it squeaks too when im not moving and i turn the wheel.
Old Feb 6, 2003 | 08:47 PM
ace1875's Avatar
Then I think its bushings if they aren't gone then look at coil bushings.
Old Feb 6, 2003 | 08:49 PM
elwood's Avatar
Sounds like the coilovers
to me. Did you put all of
the rubber pieces on?
Spray everything on the
coilovers with wd-40.
Old Feb 6, 2003 | 08:50 PM
00fbp's Avatar
thanx.. ill check out the bushings tomorrow.
Old Feb 6, 2003 | 08:53 PM
00fbp's Avatar
Default Re: squeaking sound (d15dude)
ive had the coilovers for a year now and they never made those sounds before and yeah all the rubber pieces were put on. but they might have worn off already.
Old Feb 6, 2003 | 09:02 PM
00fbp's Avatar
any other theories why it could be making that whining/squeaking sound when i turn the wheels? thanx
Old Feb 6, 2003 | 09:04 PM
Hammett's Avatar
did you do a full brake job or just change the pads?
Did you turn the rotor?
Old Feb 6, 2003 | 09:06 PM
00fbp's Avatar
Default Re: squeaking sound (Hammett)
i just changed the brake pads.
turn the rotor???
Old Feb 6, 2003 | 09:07 PM
Hammett's Avatar
resurface the rotor.
Old Feb 6, 2003 | 09:09 PM
00fbp's Avatar
oh no i didnt resurface the rotor.
Old Feb 6, 2003 | 09:12 PM
Hammett's Avatar
Thats prolly why its making the noises.
Old Feb 6, 2003 | 09:16 PM
00fbp's Avatar
thanx for all your responses im gonna check it tomorrow and see what the problem is.
Old Feb 7, 2003 | 08:47 AM
93civEJ1's Avatar
dude mine does the same...but i think its like my tierod needs to be lubed or something??
R_A_Y_N_E
Suspension & Brakes
10
Oct 1, 2015 07:35 PM
06mmDc5
Dec 6, 2012 09:46 PM
ravenger
Honda Civic (2001 - 2005)
Nov 1, 2007 07:56 PM
AsnRefugee
Sep 30, 2002 06:18 AM
