Removing Door step pannel on hatch?
Old Feb 6, 2003 | 08:04 PM
andrew dc's Avatar
Default Removing Door step pannel on hatch?
I am trying to tuck wires under my carpet on the pass side and am trying to remove the star bolt the plastic panels that surround the bottom of the door. what size or tool do I use to remove this?
Thanks andrew
Old Feb 7, 2003 | 05:54 AM
spiceisler's Avatar
Default Re: Removing Door step pannel on hatch? (CRX25)
You will need a "torx" socket/wrench. They come in a variety of sizes. Your local ato parts store should have them. I removed mine with an "allen" wrench. Again same idea. Comes in various sizes.
Old Feb 7, 2003 | 07:36 AM
andrew dc's Avatar
Default Re: Removing Door step pannel on hatch? (clean90Si)
I tried the alan wrench, it almost stripped the screw...
6 or 8 pointed? and the size? (sorry, I'm at work and want to get this done.)
Andrew
Old Feb 7, 2003 | 09:31 PM
Infinity_Racer's Avatar
its a T40 bit...bought some earlier this week and ended up breaking the tool...then found out that my dad was hiding another tool set from me and found a bit in there...with a lot of cursing and force and degreaser, all 4 bolts finally budged...HTH
Old Feb 7, 2003 | 10:29 PM
Louie B.'s Avatar
Default Re: Removing Door step pannel on hatch? (Infinity_Racer)
Go to a quality tool dealer (someone who offers a lifetime waranty and accually backs it up, because you will probably break it) and ask for a T-40 socket (If they don't know what you're talking about, slowly back up out of the door and go somewhere else) . Attach that baby to a big, long breaker bar because those bolts are going to be tight!!.
Also, once you get the bolts out, the carpet will be attached to those panels, so you can't take them all the way out. Just pull them up enough to get your wires in there.
Old Feb 11, 2003 | 07:21 AM
andrew dc's Avatar
Default Re: Removing Door step pannel on hatch? (thumpu77)
thanks guys! I will do that asap.. I am assuming I can get this bit at home depot?
Old Feb 11, 2003 | 02:43 PM
You can probobly get it at Home Depot, but Advanced Auto has em too...maybe other shops like that...HTH
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
importfan85
Aug 20, 2008 07:30 PM
Toroke
Apr 14, 2006 03:55 PM
verseone
Sep 11, 2003 07:41 AM
G2turbo_terror
Jul 1, 2003 11:46 PM
