Which proportioning valve is this?
This supposedly came off a 92-95 Civic SI.
The only marking evident on the back are 3 circles each containing one letter/number: 4 T 4. Is this a 40/40 PV? Would it work on a 94 VX with 4 wheel GSR disk brake conversion?
I just was worrying because it looks so much different than this one:
This pic is off of http://www.hybridautomotive.com.
it will not work for ur vx cuz you dont have abs.you need a 94 n up integra rs.the rs have 6 lines and which dont have abs.do anyone know if we can use a proportion vavle from a second gen integra???with rear disc
That is a prop valve off a 94-+ Integra...you are looking for a "4040" prop valve which comes from a 92-95 Civic Si hatchback...you can also use the prop valve from a 92-93 Integra GSR or GS as long as it has 4 wheel disc brakes...
Yeah thats a valve for an ABS system, no good for a non-abs brake upgrade. I almost got the same piece when i striped a local trashed gsr for stuff.
So basically what I'm looking for (besides the 40/40 stamp) is a valve that has 2 hard lines going into it from the drivers side and has 4 hard lines coming out towards the passengers side. Correct? Do all of them look like the one picture from hybridautomotive.com?
those that are doing a rear disc convertion on civics, regardless if you use front gsr brakes or utilizing your stock civic brakes you can still use a 3030 prop valve.
spencedogg
19
Jun 11, 2003 09:02 PM
