PM6 ECU on CRX HF motor?
Old Feb 6, 2003 | 07:20 PM
CRX A4's Avatar
Default PM6 ECU on CRX HF motor?
I got an extra PM6 ECU from a friend, I was told that if I put this ECU on the stock HF motor, it will add some power
My question is, will there be any side effects or any problems from using the PM6 on the stock motor?
Any help would be great
Thanks
Old Feb 6, 2003 | 08:37 PM
ScottEK's Avatar
Default Re: PM6 ECU on CRX HF motor? (CRX A4)
hmm I see no one is answering, here are some things to consider...
They are both MPFI engines.
The HF ECU would have fuel maps set up to run lean for better MPG (HF = High Fuel)
The SI maps would be more agressive and rich.
Either way I dont think you are going to see much out of the HF
I have never tried this swap, but the above facts are true so theoreticlly it seems like it would work.
Old Feb 6, 2003 | 08:45 PM
Red_Si's Avatar
it may add a little power but i wouldn't be revving as high as the rev limiter because you may blow the hf motor, i don't think it can take much of a rev over 5-5500 rpms. You may feel a little difference but it will definately run rich, my friend did this last year, he said he felt a difference in power but i didn't and we both noticed it was pretty rich for that motor. HIH
Old Feb 6, 2003 | 09:33 PM
iwouldHITit's Avatar
so will this be good if i was going to turbo my HF motor? i was going to boost my hf untill it gets focked up then ill do my si swap..
Old Feb 6, 2003 | 10:53 PM
turbohf's Avatar
Default Re: PM6 ECU on CRX HF motor? (iwouldHITit)
umm throw it in there, im sure after a couple 6500rpm shifts you will be ready for that Z6/ZC/B16/B18/whatever swap
Old Feb 7, 2003 | 12:32 AM
TeamUndefinedHFCRX's Avatar
Default Re: PM6 ECU on CRX HF motor? (turbohf)
i tried that for fun on my d15b6. the motor cant rev higher than 6000 because the stock intake man./ head blah blah is too restrictive. maybe if you plan to turbo the hf motor the si ecu would run good, but dont take my word for it. just drop in a d16a6 already. haha. peace
Old Feb 7, 2003 | 05:05 AM
rioninja's Avatar
Default Re: PM6 ECU on CRX HF motor? (TeamUndefinedHFCRX)
Your correct. A lot of people on here think that the HF has a 5500 rev limiter, but actually it doesnt. THe motor just cant physically rev higher than that.
Old Feb 7, 2003 | 06:14 AM
CRX A4's Avatar
Default Re: PM6 ECU on CRX HF motor? (Rioninja)
well i just put the pm6 in, the car has a noticible increase in power , well not that much, just a little , but every little bit helps in an HF , but the car does run very very rich, when cold the car bogs down then revs, the HF shift light is also gone, the only problem i ran into was that, i got a CEL, while driving, any ideas? the light came on when i shifted early from 1st to 2nd (keep in mind it is an HF tranny)
Old Feb 7, 2003 | 09:23 AM
CRX A4's Avatar
Anyone?
Old Feb 7, 2003 | 11:34 AM
ScottEK's Avatar
Well tell us what CEL it is giving you and maybe we can help out, you installed the ECU so you obviously know where it is. With the car off, turn the key to on and count the number of times the light on in the center of the PM6 flashes.
EDIT: The HF had a shift light on in the console?
[Modified by beta13, 2:34 PM 2/7/2003]
Old Feb 7, 2003 | 01:51 PM
audioroach's Avatar
Default Re: PM6 ECU on CRX HF motor? (beta13)
No scott...the shift light is in the guage cluster...it flashs at the
optimal shift points to get the highest fuel milage ( remember its
a gas sipper)
Old Feb 7, 2003 | 05:55 PM
333's Avatar
333
Default Re: PM6 ECU on CRX HF motor? (audioroach)
I did the same. I put a SI ecu in the hf. Very rich, But I also put in b16a 240cc injectors and fp regulator and lowered the pressure down to 20 at idle. Little help. But the SI ecu can be chipped. I have a turbo to go on the hf. Just want some safe passing power. HF manifold mounted to a kkk Audi turbo, tial 35 mm wastegate, mazda mx 6 turbo intercooler mounted under the hood where the battery used to be. The battery is in the trunk. I cut a hole in the hood to cool the intercooler. Looks pretty funky. Best thing about the HF is that it makes more torque than horsepower so boosting it will give it a nice pull. The best thing is that I will be shifting all before 4500 rpm. Should be pretty quick for a sleeper. I think I will have more fun with this than my race car. Hf tranny is great, I have a wide band 02 sensor to get the mixure just right so every thing will be just fine, worry free.
Old Feb 7, 2003 | 05:58 PM
333's Avatar
333
The light you will get will be 02 sensor, that's what happened to me. Even if you replace it it will still come on. Must be a big difference in the fuel maps between SI and HF ecu. Again, the SI ecu can be modified. I also tried to lower the fuel pressure to 20 psi at idle. Still to much gas.
Old Feb 7, 2003 | 06:01 PM
Hondasaurs's Avatar
After I swapped my Si out I gave my PM6 to a buddie of mine who had an HF. He ran that ECU for almost a year, beating the snot out of the HF the best he could and never had a problem with it.
onlya1.1L
May 23, 2005 03:36 PM
cbrman
Feb 24, 2005 09:43 AM
Ronin Panda
Jul 12, 2003 12:31 PM
IamVtec
Aug 29, 2002 09:58 PM
