spits and sputters low rpms
Old Feb 6, 2003 | 04:32 PM
tegrakid's Avatar
Default spits and sputters low rpms
have 90 acura integra LS jus installed new LS motor my first motor blew but my ?? is the 1st motor skipped really bad i went through the ignition and installed a new fuel filter now on my 2nd motor the problem has only gotten worse someone suggested the ecu could go bad.. will it? and does anybody have any suggestios to cure this on going problm pleez help the LS thinks its vtec only drives smoth above 4000 rpms crusing sucks it embarrising with it actingcrazy thanx ahead for any info
Old Feb 6, 2003 | 04:39 PM
texan's Avatar
Default Re: spits and sputters low rpms (tegrakid)
Sounds like a vacuum leak. Or at least 10 other possible things. Take it to a mechanic.
Old Feb 7, 2003 | 06:48 PM
tegrakid's Avatar
Default Re: spits and sputters low rpms (texan)
it throwing code 43 "the fuel system" i bought a new fuel filter and changed map sensor any other clues or guesses
khmaiinfamous
Aug 14, 2009 03:41 AM
qpDA9tegqp
Jun 19, 2009 05:52 PM
ToKeNbLcKgUy
Apr 17, 2005 11:36 AM
fitboy
Aug 28, 2004 02:10 PM
