speedometer cable coming loose
Old Feb 6, 2003 | 11:38 AM
CHRIS 1.8's Avatar
Default speedometer cable coming loose
Does anyone have any suggestions on how to keep the speedometer cable that plugs in to the tranny hole secure?
I used electrical tape and it worked for a while, but its loose again.
Old Feb 6, 2003 | 11:40 AM
EP3_05's Avatar
Default Re: speedometer cable coming loose (CHRIS 1.8)
There is a clip that holds the cable in. It fits in a slot in the cable housing on the trans and locks the cable in place. You can get one at your local dealership. Just a word of warning...the clip can be a real pita to put on.
Old Feb 6, 2003 | 11:42 AM
CHRIS 1.8's Avatar
Default Re: speedometer cable coming loose (91civic)
By any chance, do you know what the exact name for the clip?
Old Feb 6, 2003 | 12:19 PM
yellowcrx1991's Avatar
I lost my clip and had to make do. First time I put it back in place the speedometer didn't even move while I drove. I then went back, pulled the line out of its socket and then jammed it back in until it clicked. Its been working ever since.
[Modified by yellowcrx1991, 1:20 PM 2/6/2003]
Old Feb 6, 2003 | 12:36 PM
EP3_05's Avatar
No I don't know the exact name but when I went to buy one the guy at the parts counter knew exactly what I was talking about. He even referred to it as the "jesus" clip
Old Feb 6, 2003 | 12:44 PM
JaiDM's Avatar
hahaha. that guy funny.
yup had the problem, drove with out a speed-o for 6 months. got a clip oh but duck tape works better.
CHRIS 1.8's Avatar
Sorry for the re-post.
[Modified by CHRIS 1.8, 9:49 PM 2/6/2003]
Old Feb 6, 2003 | 12:45 PM
CHRIS 1.8's Avatar
I just got back from Honda and the parts counter person couldn't find it. Does anyone know the part number or anything that can make things more clearer?
Old Feb 6, 2003 | 06:56 PM
Just536's Avatar
http://www.hondaautomotiveparts.com/
Old Feb 6, 2003 | 07:01 PM
CHRIS 1.8's Avatar
Default Re: speedometer cable coming loose (Just536)
Do you know the part number or what I should search for?
Old Feb 7, 2003 | 12:18 AM
7PSI CRX's Avatar
Go back with this picture.
Although it's not in the correct position in the pic,
the part you need is #8.
Old Feb 7, 2003 | 12:27 PM
CHRIS 1.8's Avatar
I just got the clip, does anyone know how to install it?
Old Feb 7, 2003 | 02:04 PM
Tyson's Avatar
the end of the speedo cable has a groove around it about a half inch away from the tip. you slide the end into the barrel thats sticking up at the back of the tranny. there is a slice cut into the barrel where you put the clip in and locks the speedo as well. the trick is that the speedo cable should not be completely pushed in for the correct fit, its about just 1/16th" back from as far as you can push it, and then it will click and be secured.
turbo-crx
Oct 24, 2008 06:44 PM
Smokinsax
Jul 8, 2005 08:45 AM
DOHCRX
Mar 28, 2003 08:22 PM
