Noise with camber kit??
Old Feb 6, 2003 | 09:47 AM
thickfacek's Avatar
Default Noise with camber kit??
My camber kit (anchor bolts) from specialty products is makin some funny noises. Like when im taking off slow from a stop or just hitting small bumps in the road at a low rate of speed the front kits make some weird noises like stuff is shifting around. The alighnment is still perfect so its not like things are moving around that much. I know its not the control arms hitting because i fixed that problem a while back. Plus the noise isnt even loud, its just annoying. Something i didnt do and probabkly should do is lube those anchor bolts but i dont think thats it either. Maybe its not the camber kit at all. Anyone experience this? Let me know.
Old Feb 6, 2003 | 09:53 AM
boonacka's Avatar
Default Re: Noise with camber kit?? (thickfacek)
its the poly bushings homie! they squeek really bad when they arent lubed. just slap some lube on em and you might have a to do it a few times during the year. i spray a silicon spray on em every now and then and that keeps their mouths shut. if it were really shifting then you would notice some loose steering feeling. i htought the same thing when i first got mine and i kept trying to torque them down. i finally realized it was just the bushings squeeking.
Old Feb 6, 2003 | 01:54 PM
Turbo Dreams's Avatar
Default Re: Noise with camber kit?? (boonacka)
This is a common problem with the camber kits. Not only do they make noise, come out of adjustment. They can also bend shock towers like I have seen.
Old Feb 6, 2003 | 03:28 PM
Accord95's Avatar
sup, i have a 95 accord ex and with some negative ****** camber. i need a kit but do not know where to find a good one for a descent price. if anyone knows where i can find one please lemme know by e mail. address is maxpower5881@aol.com
Peace,
Brandon
Old Feb 7, 2003 | 10:11 PM
IwanAturBo's Avatar
Default Re: Noise with camber kit?? (Accord95)
i dont think using faul language while ure trying to ask for something is polite.. and ppl might not help u if u do that.. try to be polite and clean.. this is a good forum.. i dont wan to see it go bad.. but anyway.. try ure local shops..they should know..
Old Feb 8, 2003 | 05:55 PM
EuRoBrO's Avatar
Your bolts in the engine bay that hold the camber kit probaly came loose. This is a common problem with camber kits. Just tighten the bolts again.
Old Feb 8, 2003 | 11:20 PM
SiK AcC0rD's Avatar
i have the same camber kit on my 95 accord, i felt the same damn way yO..but i got used to it over time hehe...but when it does get annoying, i jus use silicon spray and spray it..it helps a lot, but usually when it rains, it starts sqeaking again.
Old Feb 9, 2003 | 02:18 AM
iam7head's Avatar
Default Re: Noise with camber kit?? (SiK AcC0rD)
"negative ****** camber"
they are your friend to some degree.
how many inch you drop?
Old Feb 9, 2003 | 02:19 AM
iam7head's Avatar
thickfacek: anything you can do with your sig?
I feel like Bi_ch sliping my dog everytime i see it..
Old Feb 9, 2003 | 09:08 AM
Hondaaccordvtec's Avatar
Default Re: Noise with camber kit?? (iam7head)
I have had my Progress Camber kit for over 2 yrs. on my '94 Accord EX. Haven't had any problems whatsoever and I'm lowered 2".
Stiff_Crx
Oct 8, 2009 05:14 PM
strsi
Suspension & Brakes
Sep 12, 2005 12:32 PM
d16why
18
Oct 5, 2003 09:26 AM
SubieDude
Mar 18, 2003 08:31 AM
