Removing sound deadening tar ... from tire wells
Old Feb 6, 2003 | 07:41 AM
Tweakmeister's Avatar
Default Removing sound deadening tar ... from tire wells
Okay, most of my interior panels are void of this crap.
Next I want to get some of the tar (rubber material) out of the tire wells/underbody. I understand it also protects the metal but that's beside the point
I'm guessing a power washer/sand blaster is the easiest way. Is there any chemical that is easily available that will do this?
Old Feb 6, 2003 | 08:30 AM
OC 335i's Avatar
Default Re: Removing sound deadening tar ... from tire wells (Tweakmeister)
Try NOS.
Old Feb 6, 2003 | 08:40 AM
martini's Avatar
I have yet to try it, but I've heard that a heatgun is the best way.
For the sound deadning tar on the inside, dry ice is the best way.
Old Feb 6, 2003 | 10:05 AM
ejprimo's Avatar
Default Re: Removing sound deadening tar ... from tire wells (martini)
why not just remove everthing from your car and have the shell acid dipped.
Old Feb 6, 2003 | 03:29 PM
Default Re: Removing sound deadening tar ... from tire wells (ejprimo)
NOS? That's a brand name.
I might try a heatgun...but I'm willing to bet it's too messy and won't take enough off.
I would love to do the acid bath (a la Spoon mobile) but it ain't gonna happen
The dry ice thing won't work on this stuff. I might try aircraft stripper.
[Modified by Tweakmeister, 7:29 PM 2/6/2003]
Old Feb 6, 2003 | 04:41 PM
turbohonda's Avatar
Try a wire brush wheel on a die grinder or high speed air tool, it will take it to bare metal.
Old Feb 6, 2003 | 07:21 PM
Default Re: Removing sound deadening tar ... from tire wells (turbohonda)
hmm now that's more like it.
I did a boat trailer that way once...
Old Feb 6, 2003 | 08:19 PM
jweller's Avatar
I'd try a good paint stripper on it. there is an orange one that I get at Home Depot that works really well. as good as aircraft remover but without all the nasty fumes. I forget the name though
edit: citristrip
[Modified by jweller, 2:36 PM 2/7/2003]
Old Feb 7, 2003 | 10:03 AM
spikius's Avatar
Default Re: Removing sound deadening tar ... from tire wells (jweller)
Aircraft remover didn't work on the undercoating on my teg, kinda surprised me. A wire brush does work great (on a grinder of course), as well as ridiculously intense heat (not necessarily a good idea in a lot of cases). I was seam welding a lot of the inside of my engine bay and on the side opposite the welds the tar material had peeled back in a sort of sheet like form leaving no residue, but I think it probably would take a lot of heat and a lot of care to remove it that way, since you'd have to watch out and protect anything on the other side of the material. So a wire brush is probably a faster/easier way, although it might be messier (it will probably fling lots of slightly sticky black dust around, so watch out.)
Old Feb 8, 2003 | 01:40 PM
Default Re: Removing sound deadening tar ... from tire wells (spikius)
alrighty guys thanks for the advice. when it gets a little warmer out I will start at this.
Old Feb 8, 2003 | 07:27 PM
krbobcat's Avatar
I've done this on all of the race cars we've built and I just did this today to my new project. The method I've found to be the best is just an angle grinder with a really stiff wire wheel on it. It is incredibly messy and IS NOT FUN but works pretty quick. I suggest taking everything out of the wheel well or else it will be covered in this crap. Try to cover every inch of yourself because most of it will be on you. Also, either cover your floor or vaccum frequently - if it builds up and you step in it, it will stick to your floor and leave marks.
I would not try to "burn" it off. It creates some serious smoke/fumes and smells really bad and becomes a sticky and gooey mess.
Old Feb 11, 2003 | 12:44 PM
Default Re: Removing sound deadening tar ... from tire wells (krbobcat)
okay...
looks like I'm in for a big mess if I try to do this.
thanks for the input
Old Mar 10, 2003 | 01:16 PM
civura R's Avatar
i heard jasco will take anything off but havent tried it yet
Old Mar 10, 2003 | 01:43 PM
Timmayeg's Avatar
New User
Default Re: Removing sound deadening tar ... from tire wells (civura R)
dry ice and a chisel
Old Mar 10, 2003 | 01:47 PM
Timmayeg's Avatar
New User
Default Re: Removing sound deadening tar ... from tire wells (MEGA EK)
Try NOS.
also a good idea, kinda $$$ though. freeze the **** out of it
rycrkt
Paint and Body
May 3, 2011 07:22 PM
CB
Dec 7, 2007 08:24 PM
VisualAutoMotoring
Aug 4, 2002 11:33 AM
CHRIS 1.8
11
May 17, 2002 10:09 AM
CHRIS 1.8
May 17, 2002 06:52 AM
