installing a zc in a 91 civic hb dx
need more info - is this a DOHC ZC? - what tranny are you using? - in any case, the first thing you need to do is convert from DPFI to MPFI, which just requires an injector resistor box and some wiring - you can pick up the injector resistor box from a salvage yard for very little money - one from any early civic/crx/integra will work.
well I'm thinking of using a si tranny and it is a DOHC ZC but will i have to use diffrent half shafts or will dx half shafts be alright and are they the same spline. also what about ecu wireing and what kind of ecu should i use also is there and sights that i can go to to see a list of stuff and how to install
with the Si tranny your axles will be o.k. - for ECU, use 88-89 integra
when getting the Si tranny, don't get 88 or you will have to change clutch - personally i would put new clutch in anyway, so then it wouldn't matter which year tranny as long as you get the clutch to match
[Modified by jlicrx, 10:48 AM 2/6/2003]
2fast4udude
16
Jul 23, 2007 09:33 PM
HondaCivicVX94
11
Dec 12, 2004 05:39 PM
Robster Craw
May 22, 2003 11:24 AM
