FS: Alpine CD Receiver CDM-7861 "Mint" Condition $125 SHIPPED
I got a new head unit thus have no use of this head unit anymore. Asking $125 shipped and remote included. IM for more info. THanks.
Details:
BRAND NEW ALPINE CDM-7861 CAR CD CHANGER RECEIVER. The CDM-7861 features a MaxTune Tuner, Preset Stations (FM:12/AM:6/DAP:6), D.A.P. (Direct Access Preset), Auto Memory, Local/DX Selection, CD-R Compatibility, Digital Servo, Music Sensor, Forward/Backward, Disc Play/Pause, M.I.X. (Random Play), Direct Disc Select, Music Sensor, Forward/Backward, CD Shuttle Control Function, 45W x 4 High Power Amplifier, 2 PreOuts, Bass Engine, Subwoofer Level Control, Bass Center Frequency Control, BBE. Get it now.
Specs:
Features
Tuner
ĄP MaxTune Tuner
ĄP Preset Stations (FM:12/AM:6/DAP:6)
ĄP D.A.P. (Direct Access Preset)
ĄP Auto Memory
ĄP Local/DX Selection
ĄP Preset Address Indicator
ĄP FM Stereo Indicator
ĄP Up/Down Seek
General-Head Units
ĄP CD Shuttle Control Function
ĄP 45W x 4 High Power Amplifier
ĄP 2 PreOuts
ĄP Bass Engine?
ĄP Subwoofer Level Control
ĄP Bass Center Frequency Control
ĄP BBE
ĄP Separate Bass & Treble Control
ĄP Fader & Balance Controls
ĄP S.T.M.(Source Tone Memory)
ĄP Operation Indicator
ĄP Clock
ĄP Swing Face Mechanism
ĄP Detachable Trim Plate
ĄP Anti-Theft Detachable Front Panel
ĄP Wireless Remote Controller Ready
ĄP Power Antenna Lead
ĄP Remote-on Lead
SPECIFICATIONS
FM Tuner
ĄP Tuning Range- 87.7-107.9MHz
ĄP Mono Usable Sensitivity- 0.8/9.3 (uV/dBf)
ĄP 50dB Quieting Sensitivity- 1.3/13.5 (uV/dBf)
ĄP Alternate Channel Selectivity- 80.0 dB
ĄP Signal-to-Noise (S/N)- 65.0 dB
ĄP Stereo Separation- 35.0 dB
ĄP Capture Ratio- 2.0 dB
AM Tuner
ĄP Tuning Range- 530-1. 710 kHz
ĄP Usable Sensitivity (IEC Standard)- 22.5/27.0 (uV/ĄP Wow & c
ontrol Range at 60Hz- ? 15 dB
ĄP Bass Center Frequency Selection- 60Hz /70Hz /80Hz 90Hz /100Hz /130Hz /150Hz /180Hz
ĄP Subwoofer Level Control Range- 0 To -15dB
ĄP Chassis Size (W x H x D)in- 7Ox2Ox6-1/8O
ĄP Pre Output Voltage (Before Clipping)- 2V
ĄP Treble Control Range at 10kHz- ? 10 dB
ĄP Operating Temperature (!C/!F)- 60!C (140!F) to -10!C (14!F)
ĄP Power Requirement- 14.4(11-16) V.DC
ĄP Maximum Mounting Angle- 30! from Horizontal
ĄP Chassis Size (W x H x D)mm- 178mm x 50mm x 155mm
ĄP Nose Piece Size (W x H x D)mm- 170mm x 46mm x 18mm
ĄP Weight- 1.5kg (3lbs. 5 oz)
ĄP Maximum Power Output (Note 1)- 40Wx4
ĄP Continous Power Output (Note 2)- 19Wx4
ĄP Nose Piece Size (W x H x D)in- 6-3/4O x 1-13/16O x 11/16O
ĄP Note 1: Under maximum operating voltage and input signal, into 4 ohm loads-
ĄP Note 2: Per EIA-517 standard, 40Hz to 20Hz, 0.8%THD, with 14.4 volt DC Supply-
[Modified by C-Mugen R, 9:29 AM 2/6/2003]
Details:
Specs:
Features
Tuner
ĄP MaxTune Tuner
ĄP Auto Memory
ĄP Up/Down Seek
General-Head Units
ĄP 2 PreOuts
ĄP Bass Engine?
ĄP BBE
ĄP Clock
ĄP Remote-on Lead
SPECIFICATIONS
FM Tuner
AM Tuner
I might be interested. Not 100% sure yet.
Will let you know. Do you have AIM? If so, could you email me your s/n? (eluzion@softhome.net). Thanks
blkcivichatch
Audio / Security / Video
17
Nov 26, 2005 10:28 PM
