#1 cyl pos. code
Old Feb 5, 2003 | 09:33 PM
derangedcrx's Avatar
Default #1 cyl pos. code
pos.93 ls in 89crx hf what is causing it to throw #1 cyl. pos.
Old Feb 5, 2003 | 09:56 PM
the DR.'s Avatar
Default Re: #1 cyl pos. code (derangedcrx)
check your distributor/wiring. what distributor are you using? are you using an OBD conversion harness, need more info...
Old Feb 8, 2003 | 11:04 AM
MONSTERZC's Avatar
it sounds like the crank angle sensor went bad if it did you have to buy a new dist.
Old Feb 8, 2003 | 01:59 PM
USDM 4G VTEC's Avatar
blue/grn a and blue/yellow wires are inverted on the distribuitor.
switch them and check if it goes away
but its a #1 cyl prob
called as a CYL sensor on OBD
Rhood
39
Apr 6, 2017 10:03 AM
Nathan_volcom
Oct 21, 2011 05:49 AM
twitch27
Sep 10, 2008 08:35 AM
PrecisionPerformanceParts
Jul 28, 2005 10:23 PM
Ukraine Train
Jul 21, 2004 12:16 PM
