Replaced fuel pump and it still wont....turn on?
Old Feb 5, 2003 | 08:21 PM
Agent Daimon's Avatar
Default Replaced fuel pump and it still wont....turn on?
i replaced the fuel pump on my dads 88 civic lx..and i dont hear it turn on..what other problems should i look out for? im gonna replace the main relay tomorrow..and i replaced the fuel filter alreadyy...hmmm
btw i did a search.
Old Feb 5, 2003 | 08:33 PM
90RioGS's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (Agent Daimon)
Most likely your main fuel relay, so if you're replacing it tomorrow that should do the trick!
Old Feb 5, 2003 | 11:14 PM
Creamies's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (90RioGS)
If not the relay, then try getting a better ground. i had that problem.
Old Feb 6, 2003 | 08:26 AM
zCivic's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (Creamies)
Can you hear the main relay click when the CEL goes off. Turn on the switch and when the CEL goes off will hear the main relay click, if not its going/gone bad.
Old Feb 6, 2003 | 08:36 AM
tilt's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (zCivic)
Yep I had a bad ground to the main relay AND a bad fuel pump. Took a while to figure out. Simplist thing to do is swap out the main relay and if it still doesnt work use a multimeter and check the wires out using your manual.
Old Feb 6, 2003 | 07:57 PM
sporkcrx's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (tilt)
Check all the fuses.
Old Feb 7, 2003 | 09:15 AM
therealciviczc's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (sporkcrx)
Yeah, it sounds obvious, but the fuel pump runs off of a fuse that mentions nothing about the fuel pump... it's something like ECU, or something not fuel related. I think its a 15amp or 10amp fuse in the under dash box.
Mine blew once... it was very tough to notice. I would have never caught it if I hadn't removed every single fuse an looked at it.
[edit] blue... blew... their... they're... there... your... you're...
[Modified by therealciviczc, 6:16 PM 2/7/2003]
Old Feb 7, 2003 | 03:58 PM
sporkcrx's Avatar
Default Re: Replaced fuel pump and it still wont....turn on? (therealciviczc)
Yea, the day after I installed my walbro it blew the fuse for the alternator or some ****. That's why I say just check out all the fuses, get a test light, ground it, and touch the small metal square on the top of each fuse (2 on each) and make sure the both either light up or dont.
Old Feb 9, 2003 | 12:21 PM
UPDATE:
i replaced the main relay..and i turned the ignition to "on" to hear the fuel pump..but i still did not hear anything...then i peeked under and i saw fuel leaking out...damn this shizzzz..what else could it be?
[Modified by Agent Daimon, 9:22 PM 2/9/2003]
Old Feb 9, 2003 | 01:06 PM
AbaZ's Avatar
check fuel pump ground..
10mm thermostat ground.
Jeff
3easy21
Jun 11, 2012 07:27 PM
ghettoda9
Apr 13, 2011 10:03 AM
8_6 luder
Aug 5, 2007 06:27 AM
b18c1civic95
Nov 28, 2004 07:09 PM
shoebox
Feb 11, 2004 11:18 AM
