VAFC horsepower gains?
Old Feb 5, 2003 | 07:39 PM
gsrteg's Avatar
Default VAFC horsepower gains?
will everyone that runs an Apexi VAFC and has had access to a dyno please post the power increases with this unit installed. I want to know if this is the **** or not. thanks
Old Feb 5, 2003 | 08:12 PM
texan's Avatar
Default Re: VAFC horsepower gains? (gsrteg)
it's not ****, but it's effectiveness depends on whether or not your motor needs different fuel delivery from what it's getting now. Unless someone posts up a dyno chart with a nearly identical engine setup to yours, the information will be useless.
Old Feb 5, 2003 | 08:18 PM
gsrteg's Avatar
Default Re: VAFC horsepower gains? (texan)
true, but bye using a VFAC will there be a noticable increase in power if tuned correctly when used on a engine that is FAR from "factory tuned", so to speak.
Old Feb 5, 2003 | 08:34 PM
marc.ejay-twenty's Avatar
it depends a lot on what mods you have. in my opinion, a vafc is most effective if you have big cams or some kind of FI
Old Feb 5, 2003 | 08:51 PM
gsrteg's Avatar
Default Re: VAFC horsepower gains? (marcdogg816)
My setup is, as listed: 94 integra GSR, Ls/Vtec B18a block,B16a head, B16b 81.25mm pistons/rings, factory modified rods, ARP rod bolts, JDM SiR P30 ecu, stock injectors, and acutally I plan on pickup up some 97 spec ITR cams tomarrow and installing a B&M FPR. Just ball park guessing. Would this setup benifit from the mods listed or would the results remain unnoticable if you will. thanks for helping guys.
Old Feb 5, 2003 | 08:53 PM
gsrteg's Avatar
benifit with a VAFC is what I was saying
Old Feb 5, 2003 | 08:57 PM
texan's Avatar
Yes, that ECU is not tuned to feed fuel for a 1.8L with ITR cams and a ~12:1 CR. Nor is the timing correct for the compression.
[Modified by texan, 9:58 PM 2/5/2003]
Old Feb 6, 2003 | 05:52 AM
piotrush's Avatar
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
This is the link to my plot for a h22a4. This was done on an otherwise stock car - not even a CAI at the time. The only noticable diffrence was at the crossover point. According to the graph, at the x-over pt, I gained ~15whp. Not bad IMO.
gsrx
Nov 24, 2004 02:12 PM
Behan
Jun 8, 2003 05:46 PM
CALM_AS_A_BOMB
Mar 28, 2003 09:40 PM
Hoagieryder
Apr 25, 2002 02:47 PM
capcon83
Mar 11, 2002 05:54 AM
