FS: 1999 Supersonic Blue Integra GSR
I'm trying to sell the car as a whole one last time. References will be furnished at request.
Reason for selling... I need a AWD car
I'm interested in trades as well... WRX, A4 quarttro, S4, GSX, ect...
Information: 1999 Acura Integra GSR Supersonic Blue Pearl. This car has a stock motor with a compression test of 190psi in all four cylinders. This car has 40k original miles. Recently changed timing belt, front brake pads, and battery.
Dyno: 245whp / 185 wtrq @ 10psi (GruvyTune can verify these numbers)
VIN: JH4DC2390XS003850
Factory Options:
Factory Options: Leather Int, Pwr Windows, Pwr Door Locks, Pwr Mirrors, Pwr Sliding Moonroof, Rear spoiler, Alloy Wheels, Cruise Control, Tilt Wheel, ABS Brakes, CD Player, LoJack Security System.
Here is the list of modifications:
Genuine JDM front end w/ front lip spoiler
GReddy turbo kit (TD05-18G turbocharger) w/ GReddy type 24 Intercooler
GReddy Type-S blow-off valve
Hondata 2B ECU (fully tuned by Torin aka GruvyTune)
OBDI P72 ECU conversion w/ OBDII to OBDI wire harness
Philips 4300k HID kit
Hella Supertone Dual Horn kit
MSD SS Blaster coil
MSD Shift Light w/ 7000 rpm pill
RC Engineering 440cc fuel injectors
AEM fuel pressure regulator
Walbro 255lph intank fuel pump
Spoon oil cap, radiator cap, oil pan plug
Porterfields RS4 brake pads
Exedy Organic Performance Clutch
OEM Integra Type-R flywheel
DriveShaftShop.com stage 2 performance axles
OEM side, rear skirts
Honda S2000 antenna conversion kit
Metallic silver window tint (37% legal)
GReddy Power Extreme 2 cat-back exhaust (70mm piping, 4in tip)
H&R sport springs (1.75in F, 1.5in R)
KYB AGX shocks
Ingalls front & rear camber kit
RacingHart M5 EVO (17 x 7)
Toyo T1-S tires (205/40/17)
GReddy 52mm electrical boost gauge
GReddy 52mm electrical EGT gauge w/ probe
GReddy ProfecB boost controller (black)
GReddy Turbo Timer (black)
OEM Integra Type-R titanium shift ****
C’s short shifter kit
Asking price: $21,500
[Modified by mod5, 11:52 AM 3/4/2003]
Factory Options:
MSD SS Blaster coil
KYB AGX shocks
heres a bump your car is very clean and id say a good deal for what you have and what your asking. that guy that said he is looking for something cheaper, that is looking for a turbo type r in the VA area is trippin there is no way he will find a boosted type r with a jdm front for less than what your asking but i guess he will get to find that out good luck on the sale
I read the first post, but would you consider parting it out? Or are you going to save that as a last ditch effort?
What about the car in stock form minus the JDM Front end?
I know its a lot to ask but if it makes you get a sale, it makes you get a sale.
