Help with Oil Squiter
Old Feb 5, 2003 | 10:03 AM
B20-T's Avatar
Default Help with Oil Squiter
Hi i have a b20 bottom end with a 99 type r head.I am wondering is it possible to add a gsr gridle,and gsr oil squiter to the b20 bottom end?if so what do i need to install this into my b20 bottom plmk thanks.
Old Feb 5, 2003 | 10:08 AM
b18bturbo's Avatar
Default Re: Help with Oil Squiter (B20TURB0)
you have to drill and tap the oil squirtes and the girdle is pretty easy to do if you know what you are doing. Just get the girdle from gsr machine it. Dowel it and be done with it.
If you want easier setup get z10 girdle and there installation kit with dowels.
Old Feb 7, 2003 | 09:03 PM
Flamenco-T's Avatar
you may not be able to fit an oil squirters on a B20 crank..the journal is too large to fit...
as far as girdle, run Z10....if you tap a dowel pin on a regular GSR girdle, it may not fit right on the bolts..
DAchiko
Feb 17, 2009 04:44 PM
red02s2k
May 8, 2008 08:10 PM
aych2h
Feb 7, 2007 08:22 AM
loudassVTEC
Nov 5, 2005 06:01 PM
