95 custom civic OVER 18 k invested turbo,dohc,alpine
Old Feb 5, 2003 | 06:16 AM
civictypenos's Avatar
Default 95 custom civic OVER 18 k invested turbo,dohc,alpine
Asking $15k FIRM. LESS THAN 60k MILES
VIN # 1HGEJ2125SL033111
front
back,notice the tailights red flipped over clear
mobil one used every 4 months or 2k miles
front again
custom ceramic coated manifold
alpine cva 1005
JL Audio with custom pods
controls a few things on the car
Little dark,sorry
Alpine changer and surround sound proccesor
big bad T3 with new center section
Type r manifold polished inside and out
ENGINE
DOHC B16A3 (polished block)
Tranny from del sol w/ DOHC (polished casing)
Type R Intake manifold (ported and matched to head)
Type R valve cover (cut to adjust cam gears)
Polished spark plug cover
STR oil dipstick
remote oil filter setup
weapon R cam gears
STR cam cover oil gasket
Jun ULTRA light flywheel
ACT extreme pressure plate with street disc clutch
AEM pulleys
nuespeed shifter bushings
H22 throttle body
COOLING SYSTEM
two slim line fans
Del Sol dual core radiator (twice as think as stock)
IGNITION
MSD distributer cap
Crane ps 92 coil
Crane Hi-6 igntion
Magnacore spark plug wires
ZEX spark plugs
ENGINE MNGMT.
APEXI Vafc
MSD Boost timing retard module
P30 ecu chipped to 9500 rpm
Techedge wideband kit with palm pilot and display unit
TURBO
T3 turbo
custom equal length turbo manifold (ceramic coated)
custom mandrel bent charge piping for turbo
custom downpipe (with fiber wrap)
huge 30x6x2.75 inch intercooler
Pep boys filter
Greddy Blow Off Valve
Missing link
misc lines,fittings, heat wrap,t bolts
manual boost controller
FUEL SYSTEM
RC 370 cc injectors
AEM fuel rail
Gauge on fuel rail
Walbro 255 liter /h intank pump
AEM fuel pressure regulator
EXHAUST
dual NAXOS mufflers "y"ed off behind axle
NO catalitic converter
OUTSIDE
Blue electron pearl (labor for all shaved stuff included)
Andys Autosport body kit
shaved emblems
shaved antenna
shaved handles
shaved tag holder
Dragon fiberglass hood
Z3 fenders (not on yet)
Euro antenna
LIGHTING
Denji projector lights
hyper white bulbs
clear EURO corner lights W/ hyper white bulbs
white sidemarkers
custom taillights (made to look like 00 si lights)
hyper blinker
INSIDE
Gsr black cloth seats
JDM audio console
SI armrest
power windows
custom switch panel
3 gauge piller
EX gauge cluster with tach
EX clock
Custom door panels with leather inserts and custom speaker pods for 3 speakers
Custom door handles (just buttons for shaved handles,no latchs)
back dash covered in leather
EX rear speaker covers
FULL dinomat inside with padding (doors and roof,everywhere)
black carpeting
Trunk covered in custom leather panels for stereo system
Carbon fiber dash overlay
Indiglos
type r shift boot w/ emergency shift boot(not installed yet)
fake pedels
Shift ****
black honda floormats
GAUGES
autometer shift light
Egt gauge
Oil temp gauge
Boost gauge
A/F ratio
Nitrous Gauge
Oil pressure
vtec light in dash cluster
nitrous light in dash cluster
NITROUS (intercooler sprayer)
Zex kit
bottle blanket
purge valve
misc SS lines
Front sprayer
Remote turn on
SECURITY
Sidewinder 7000 alarm (12 channels)
back up battery
fuel cut off switch
proximity detector
pops doors,trunk,gas lid,starts car,rolls windows up and down
DEI voice module
back up siren
battery relocated (to prevent thievs getting to it easily)
no door handles inside or out (all done by remote or buttons)
aqua colored flashing light for security
Remote start
other things i wont mention on the web
AUDIO
CVA 1005 Headunit (alpine indash TV monitor)
HVA 510 Alpine surround system
Pyle dvd player
TV antenneas and unit
Alpine 12 disc changer
Zapco 6 channel amp
JL audio 6 piece component system up front
JL audio 4 piece component system in rear
Custom install with leather panels,fiberglass,plexy glass and neon lights
converter for playstaion w/ cables
10 inch kenwood sub w/ box
rca links,wire and fuse holders
WHEELS
The Edge CONCEPT 7's 17 inch 7 spoke wheel (white in color)
kumhos tires
chrome tuner lug nuts
SUSPENSION
kyb agx adjustable shocks
weapon r coilovers9yeah i know,but they work for now.)
GSR front and rear brakes with 4 disc conversion
front SI sway bar
rear suspension technics sway bar
rear lower tie bar
front upper tie bar
back upper tie bar
SS brake lines
crosdrilled and slotted rotors all around
All the mods add up to over $18k,so its like getting free labor on everything and a free car with the mods.i can send a detailed break down of all the inventory on the car with prices of what i paid for the things,mostly the prices i paid for stuff was wholesale or close to it.
HISTORY 95 CIVIC DX ,bought the car in 98,paid for.Been in a minor fender bender(fixed now),has a few dings and scratchs on the paint.Front bumper has a crack,its been fixed from behind with fiberglass but needs to be fixed cosmeticaly.Car was painted 3 years ago,still looks wet.Adjustable suspension.Set of Z3 fender included.Ive invested over $18k into the car,not including any labor or the actual cost of the car.ALL work was done by me so who knows how much labor that would have costed for everything.Pictures of the trunk are very dark,the turnk is completely covered in black leather,with plexyglass over the amp,battery and surround sound processor.I worked in a proffesional stereo shop for 3 years so its been done right and clean.The stereo is awesome,the best ive ever heard in a car,the bass is not overkill and sounds just right,you would not believe the sound from this little 10.Alarm was installed like no other alarm Ive ever installed or seen installed by anyone(thats all im saying about the alarm so dont ask).tires are nearly brand new,needs alignment,camber kit should be here any day.Brakes painted red front and back.There are 7 small holes in the trunk where a wing used to be mounted. Everything on the car opens with the remote from the alarm(except hood),gas lid,doors,trunk.Has remote start,although now with the fuel cut off switch it does not work,been lazy to figure out a way for the alarm to bypass it.Turbo has about 1000 miles on it,runs strong,motor had 40 k on it when installed and now has about 43 k on it.I have most reciepts for everything.$15 k is a good price i think,basically you get alot of free stuff.Motor dynoed at 154 hp with out turbo,it hasnt seen a dyno with the turbo installed.It really needs to be tunned on a dyno and a wideband O2.A/C is intack and needs to be filled,line was just taken off for fittement of the turbo.
REASON FOR SELLING It really doesnt matter if I sell it,Im just interested in what people would pay,if someone does come up with the cash and wants it ,I WILL SELL IT.I want to sell it for a down payment on a viper .I dont drive it too much any more, id rather let someone else enjoy it than let it sit.
Car is located in central Florida.Shipping is not a probelm if you pay for it.
IM me if at all interested.
Modified by civictypenos at 12:14 PM 5/26/2003
Old Feb 5, 2003 | 06:37 AM
EKB18BPR3's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (civictypenos)
looks really good, bump!
Old Feb 5, 2003 | 08:52 AM
Skunk2_92gsr's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (dniedacess)
NICE car!
BUMP 4 U
Old Feb 5, 2003 | 09:16 AM
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (Teg44)
thank you
Modified by civictypenos at 5:55 AM 8/16/2003
Old Feb 5, 2003 | 04:50 PM
ttt
Old Feb 5, 2003 | 06:26 PM
project dc2's Avatar
show some pics of the downpipe, howd you fit an internal wastegate in there ?? with AC !??!?
Old Feb 5, 2003 | 10:00 PM
unstopabledj's Avatar
car,motor and electronics
kit,rims,lights
good luck on your sale
Old Feb 6, 2003 | 12:51 AM
Tofurky's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (unstopabledj)
kit,rims,lights
this isn't the appearance forum
good luck
Old Feb 6, 2003 | 05:39 AM
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (Ruckus138)
kit,rims,lights
good luck
thanx alot
Old Feb 6, 2003 | 10:16 AM
E-Rok's Avatar
EPIC TUNING
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (Lee Chun)
wow alot of people are simple minded. its not my tatse AT ALL (i hate body kits and all), but damn he has a FAST car, and people talk **** still. dont talk **** unless your car is faster, chances are its not
Old Feb 6, 2003 | 11:14 AM
thanx!
Modified by civictypenos at 5:56 AM 8/16/2003
Old Feb 6, 2003 | 11:41 AM
paint the hood and itll look its not that bad guys .. at least he has POWER to back up his car. the front gets a from me, just paint that hood. and engine bay looks cherry also .
Old Feb 6, 2003 | 12:37 PM
ill_take_one's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (project dc2)
Nice ride. Theres a lot of stuff that i'd rather not have if i bought it, would you part it out or not?
What times have you run with it?
Old Feb 6, 2003 | 01:22 PM
Bantam's Avatar
2nd Coolest Person in DFW
Any dynos or 1/4 mile times?
Old Feb 6, 2003 | 02:57 PM
UncleBen'sRacing's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (tharptroy)
30 whp 40 lbs tq off NAWZ, and 300 hp and 400 lbs of torque on NAWZ, he lives his life a quarter mile at a time and for those 10 seconds he's free!!!!!
[Modified by AllMotorEF9, 3:59 PM 2/6/2003]
Old Feb 6, 2003 | 05:47 PM
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (AllMotorEF9)
lol.when the motor was n/a it was putting down 154 to the wheels which is VERY good for a b16a3 with bolt ons,since ive turboed it i havnt had it dynoed,the one that i used to go to in town closed down,i dont live far from VAPORTRAIL and id like to take it to him sometime soon,till it gets put on the wideband i dont drive it much,runs fine but id rather be safe than sorry.
As far as the hood goes,its unpainted,if i keep it im thinking of selling it and getting a carbon fiber one
And if you read closer,the NAWZZZ dog is not even hooked up to the motor,lol,it just sprays the intercooler.a freind sold me the kit for cheap and i thought id put it to good use.
thanx for the compliments,those of you who didnt puke,lol.
Old Feb 6, 2003 | 11:56 PM
Tofurky's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (rewsnaeht)
my car's faster, but I wouldn't talk ****. more importantly I wouldn't talk **** in the For Sale forum.
It's seriously getting gay how many people come in here and bash on cars. This isn't the Appearance Forum where your opinions are welcome. This is a place where people sell their vehicles. If you honestly want to tell him you don't like his car, send him an IM. No need to crap on his Sale.
And this guy is being totaly cool headed about people's ignorant comments. Psshhh.
Old Feb 7, 2003 | 04:14 AM
DSF's Avatar
DSF
If you have the time do you think we could discuss the money you've owed me for about a year? I think I've been more than fair in working with you. Why won't you return any of my IM's or emails, I'm just trying to end this in a civilized manner. Please email me...
Edit: This message is intended for Paul.
[Modified by DSF, 8:15 AM 2/7/2003]
Old Feb 8, 2003 | 06:50 AM
95GSRRacer's Avatar
Well I am not one who likes the body kits either... But that is one hell of a car you have built. Nice job and good luck with the sale! I'll bump this...
Old Feb 12, 2003 | 04:40 PM
CivicMonster's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (95GSRRacer)
That's a bomb *** ride. Looks tight. dont listen to those othe guys who are hating on you.
Old Feb 12, 2003 | 07:00 PM
Deke's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (CivicMonster)
Good work mang, looks like it can back up all that bling on the outside!
Old Feb 12, 2003 | 08:04 PM
eddiecut's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (Deke)
to all the **** on here that cant keep there damn mouth shut about stuff! if ya dont like it dont worry about it. but oh well thas life. nice motor
Old Feb 12, 2003 | 08:59 PM
YumVTEC's Avatar
Default Re: 95 custom civic OVER 18 k invested turbo,dohc,alpine (eddiecut)
white ugly hood, yellow lettering =
rest of the car is quite nice.
hope you get what you want.
Old Feb 21, 2003 | 01:34 PM
to the tizopp,YO!
Old Feb 21, 2003 | 02:56 PM
brent_G's Avatar
never saw a car like this one...bump for being different and a good setup under that cowel almost looks just like the 99-00 si...good job if you were trying to replicate it
