Can anyone tell me how to change the 2000 Accord ac air filters? How do I get to them?
Old Feb 4, 2003 | 08:38 PM
UncleRay's Avatar
Default Can anyone tell me how to change the 2000 Accord ac air filters? How do I get to them?
If the filters are located behind the center (radio, etc) consol, how do I lossen the top the the console? Access thru clock port to a screw? I found bottom 2 screws.
Thanks!
Ray
Old Feb 4, 2003 | 09:14 PM
iam7head's Avatar
Default Re: Can anyone tell me how to change the 2000 Accord ac air filters? How do I get to them? (UncleRa
pry out the clock slowly and reveal you the third and LAST screw.
the radio is hold together by the screws on the side.
Old Feb 5, 2003 | 05:05 AM
jweller's Avatar
http://board.hondasociety.com/showth...ghlight=filter
Old Feb 5, 2003 | 04:35 PM
bill-71SS's Avatar
remove the glovebox,then the support bar behind it {you will see it when box is removed} pull cover off that holds in the filter and you are there. Do not have to remove any console or clock. The lower panel on pass. side has 2 screws in the right end and 1 on the left,then it just pulls loose.
Old Feb 5, 2003 | 05:05 PM
seano's Avatar
Cheaper DIY method
mgalpy
May 13, 2007 07:41 PM
jaykav99
Jun 8, 2006 06:40 AM
accordpimpin
Nov 12, 2005 07:46 PM
mpxs20
Jul 18, 2005 02:52 PM
logic
Oct 12, 2003 03:31 PM
